Vid: Sleeb's 1/8 brushless converson
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
Vid: Sleeb's 1/8 brushless converson - 01.29.2007, 09:04 AM
Here ya go. A beautiful day outside, so it's a great time to give the Hyper a good run. Here's the specs:
  • Hyper 7 RTR
  • Feigao 10L BL motor
  • Mamba Max ESC
  • 12 cells GP3300
  • BEC disabled and RX pack used
  • 11/46 gearing
  • Road Rage tires
My gearing calc predicted 32 mph, and I hit 29, so that's a success for me. Outside temp was 55, and highest temps seen were 105 on the ESC and a bit over 100 on the motor. I've got a 13T pinion in the mail, and I may be able to go up to 15T, depending on the temps I see. Braking was great, accleration was great, heck of a lot of fun to drive...but I really need to get that big servo I got in there. The one I've got doesn't have enough muscle to turn the tires. Running in the grass is like running on concrete. Lots of control, and with the 12 cell in there and panther tires, it looks like a lawnmower from all the grass flying up.
So, next steps are:
  • Test with 13T pinion
  • Properly mount up the heatsink (remove sticker on the can and use heat transfer compound)
  • Get the Tony's screws I ordered in there
  • Get UBEC in there so I can ditch the RX pack
  • Get a 4S 4000mAh LiPo
  • Find a way to mount batteries with something other than duct tape :005:
I'm hoping for 35 - 38 mph or so after all this. 40 mph is my target, but I think I need 5S to do that. There's also the possibility that with the 15T pinion and 4S 40 mph might be in reach without overheating. We'll see how it goes from here! On to the vid!
Sleebus
Sylvester
Sylvester's Avatar
01.29.2007, 09:16 AM
Looks good sleeb. Im sure lipo will put you up there!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
gixxer
gixxer's Avatar
01.29.2007, 09:27 AM
looks good.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.29.2007, 12:07 PM
I don't think you will have any trouble hitting 40 on a good 4s pack... just drop a 16 or 18 pinion on it and it's cake. :)
AAngel
01.29.2007, 12:15 PM
sleebus,
Nice job. The cold whether you are having is definitely helping you out with the temps. I don't have much experience with 1/8 scale brushless, but I do know that the Lipo pack will give you an added kick.
Where do you get a 16T pinion anyway? What kind of runtimes are you getting?
sleebus.jones
01.29.2007, 12:35 PM
@ GD: wow, I would think that's gearing it pretty high, but i'm rather inexperienced with the L can motors. So far I'm pretty impressed! As for a good 4S pack, would a maxamps 4S 20C 4000mAh pack meet that requirement, or should I look for something better? I certainly like the maxamps price, but it doesn't do me much good if they aren't quality packs...
@ AAngel: Thanks! I belive that Mike has the 16T pinions in the store here
Sleebus
glassdoctor
TEAM FUSION
01.29.2007, 12:36 PM
Century makes mod1 pinions (helicopter brand available at TowerHobbies) up to 16T... and the 18T can be made easily from emaxx tranny parts.
Procharged5.0
Procharged5.0's Avatar
01.29.2007, 12:42 PM
Looks great. Nice seeing the video!
neweuser
neweuser's Avatar
01.29.2007, 12:45 PM
Very nice Sleeb. I like the buggy you have. I think maxamps are good. I have 5 lipo packs from him and are doing great.
AAngel
01.29.2007, 01:03 PM
sleebus,
I've used several maxamps packs. From 2S2P 8Ah 7.4v packs to 3S2P 8Ah 11.1v packs and haven't been disappointed. I haven't had any heat issues with them and the all accepted at least their rated capacity when I charged them. If you look at just the specs of the motor and batteries, the 4S 4Ah pack is capable of an 80A constant load and up 120A for a 30 second sustained burst. The 10L motor is rated at a max amp draw of 60A. I understand that the motor could demand two or three times that in short bursts, but the 4S pack is rated to 200A for short bursts, so it should do just fine.
I'm thinking that the 4S packs are going to be a nice compromise between weight and runtime. I ordered a couple and am going to see how they do in my buggy with the 7XL motor that I have coming.
As I said, I've been using the maxamps batts for a while and have no reason to doubt their ratings. I do have to tell you that maxamps has been really slow lately. They told me that they've been running behind since Christmas. My last order took them eight days to ship, so if you need them quick, you might want to spend a bit more and order it from someone else. I placed my last order on January 18 and still haven't received them yet.
Assuming that you've never had a maxamps pack before, just take note that they come with balancing taps compatible with Hyperion balancers. If you need thunder power compatible taps, you have to pay extra for those. The packs also come wired with 14 gauge wire. Going to 12 gauge is an option at added cost.
AAngel
01.29.2007, 01:16 PM
Oh...and how about some pics? I'd like to see your setup.
sleebus.jones
01.29.2007, 01:27 PM
That's comforting to hear good news on the performance of the maxamps packs. I'd heard some reports of them not being that good.
I do have pics, but the server they're on is being moved. Once that's up they'll be right here:
http://gallery.rctrack.info/sleebus_jones/Hyper7/
Sleebus
sleebus.jones
01.31.2007, 10:09 AM
I'm glad to report that the server is back up! Those of you who wanted to see pics of the setup and didn't see them before, now you can.
Sleeb
AAngel
01.29.2007, 01:43 PM
Yeah, I've heard some complaints about the maxamps packs too, but I wonder if the complaints are from people who just know somebody who said this or that, or if they are those who actually use them.
My packs have never disappointed me, but I must qualify my post above. Thus far, I've been running them in the 1/10 scale arena. I run a T4 with a Mamba Max 7700 system on 3S lipo. It's a good 60 mph rig and the batts never even get warm. I'm geared 12/87 with speed hawg tires all the way around.
How the packs perform in the 1/8 scale arena remains to be seen, by me anyway.
neweuser
neweuser's Avatar
01.29.2007, 01:54 PM
I too use the maxamps packs. They never break a sweat either. I've heard people checking their batt temps, i have never even felt my to the warm touch. I run 5s on a 10xl and never had probs. Also have 4s on a Neu 1/y and never had an issue as of yet on two runs...lol. I also have a 2s on my compx in my 18T and got about 25min if run time the other day with no probs. I love these packs! Always charge good and stay in balance well.
