Heat gun ?
rchippie
rchippie's Avatar
Heat gun ? - 04.07.2007, 08:51 PM
Hi everybody :017:
Do any of you know of a company that makes a 12v heat gun, if so can you prvide a link please ?. THANK YOU
REAL MEN RUN BRUSHLESS
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.07.2007, 09:02 PM
I don't think you will find a true heat gun in 12v... best bet is a little hair dryer.
I would suggest a butane/propane torch with a "hot air" nozzle.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
rchippie
rchippie's Avatar
04.07.2007, 09:06 PM
Do you know of 12v Hair dryer?. I Would like to use it for heating up my motor off my starter box at the track . So my motor will be eaiser to start.
glassdoctor
TEAM FUSION
04.07.2007, 09:09 PM
It will suck a lot of juice from the battery... and I doubt they really work very well anyway.
google 12v hair dryer or 12v auto accesories.... they are common for truckers, RVs, boating, etc....
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
04.07.2007, 09:11 PM
The one on this page says 14 amps....
http://www.jcwhitney.com/autoparts/B...002613/c-10101
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.07.2007, 09:43 PM
Wow, a 12v true heat gun would suck some serious current. Most 120v ones draw ~10-15A. That is between 1200 and 1800w. To get that power at 12v, you'll need 100-150A! The best you could hope for is to get a 12v hairdryer. Or, use a 120v extension cord (but make sure it uses 12-14GA wire because of the current).
nativepaul
nativepaul's Avatar
04.08.2007, 08:16 AM
You can get 12v tyre warmers with heated blankets for models (some with variable temprature) maybe 1 of those with 1 blanket wraped round the head and 1 around the crankcase would work without draining your battery so much, you could even use the other 2 blankets on your tyres.
