Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Just a quick compatibility ?......
supralover72
supralover72's Avatar
Just a quick compatibility ?...... - 04.17.2007, 03:07 PM
Will a mamba max with a fegiao 8xl be ok and have enough power from 12 Ni-Mh cells? If not, what other motor can as the cell number is set.
jhautz
jhautz's Avatar
04.17.2007, 06:43 PM
Yes it should be fine. On 12 cells the 7xl would be a little hotter/faster setup, but the 8xl will give better run time. Either should be fine. Make sure you use a UBEC with the MM on 12 cells.
to make it...
or break it...
Silent...But Deadly
04.17.2007, 07:02 PM
And I recommend a fan...
supralover72
04.17.2007, 07:56 PM
Got the UBEC, ar ethe fans sold here?
Also, thanks guys.
jhautz
jhautz's Avatar
04.17.2007, 08:00 PM
No, But he should carry them now that I think about it.
Try this for the MM ESC.
http://www.allelectronics.com/cgi-bi...LING_FAN_.html
5V runs off of the UBEC and fits right on top of the MM. 3mm screws goes right in between the fins on the heat sink. You could go with 40mm fans if you want more airflow.
to make it...
or break it...
Silent...But Deadly
HotnCold
HotnCold's Avatar
04.18.2007, 07:31 AM
you could check with mike about the fans - i know he has had some before....
Hows that "Hope and Change" working out for Ya???
supralover72
04.18.2007, 03:08 PM
Thanks guys.
