need help with getting a dependable setup
ncalenda
Need for Speed
ncalenda's Avatar
need help with getting a dependable setup - 06.18.2007, 02:20 PM
Here is my problem, I run my e-maxx on the sand, and if I try to gear it for speed, it thermal's like crazy. My goal, is to get 40+ mph on the sand with no thermal.
Here is my setup:
9920 warrior esc / with BEC
9xl motor
pro-line arm, 3.3 carriers, towers, and shocks
2 speed tranny
rrr spur 70/22
5S Lipo
12 lb truck, with lipos in
When I run in 2nd, it thernals, 1st is fine.
I also want to go with the strobe, since I have heard it is a better clutch.
When I run it on the sand, with the resistance, 2nd is no good with these gears, and I have plenty of torque, too much to be honest.
The motor was find, it was the ESC that was too hot. Can I just get a better ESC to handle this, so that I can keep this gearing (and handle the 51 spur when I get the strobe)?
Would the Monster Pro quark-125b handle it better? Or, what esc can handle this, the motor seems to be fine.
Again, I do want to go 40+, on the sand, high resistance. Also, I want to get the single speed tranny, but can't if I can't even run it in 2nd now. If I can get it running how I like, then I will get the single tranny.
  Send a message via AIM to ncalenda
