Duplicolor Metalcast, anodizing in a can...
supralover72
supralover72's Avatar
Duplicolor Metalcast, anodizing in a can... - 08.26.2007, 06:03 PM
Has anyone ever used this stuff on rc? It's been out a while and I was wondering if it's good or not.
http://www.duplicolor.com/products/metalcast.html
http://www.duplicolor.com/products/metalspecks.html
squeeforever
squeeforever's Avatar
08.26.2007, 06:17 PM
I honestly think its just a candy paint. When painted over aluminum, etc. it will look anodized to an extent. It will still look like paint I think. Mainly because paint is usually glossy, where as anodized is usually kinda flat looking.
supralover72
08.26.2007, 07:02 PM
Really? It doesn't look that glossy in the pics. Thanks.
squeeforever
08.26.2007, 07:40 PM
It's just a thought. I'm not positive, but it's a safe assumption. You can get it at Walmart I think, so I would pick up a can and try it. I might try some purple or orange now that I think about it.
supralover72
08.26.2007, 08:59 PM
Yup, I will next time I'm there, thanks. I'll let you know how it goes.
08.26.2007, 09:03 PM
I tend to like the "hammered finish" paint on Aluminum. It is semi-glossy and creates a texture to hide many minor imperfections. See my BL Conversion link in my sig to see the results.
It does chip off eventually, but so will any paint.
I use regular flat paint as a primer (regular primer doesn't stick as well for some reason), and then only a light coat of the hammered paint is needed. Otherwise, you see the Al through the little pinholes the hammered paint creates and you'd need multiple coats.
JThiessen
JThiessen's Avatar
08.27.2007, 01:51 PM
You are exactly right about that. I only know of one primer that is specifically made for AL, and it doesnt come in a spray can as far as I know. The best route for painting aluminum is to scotch brite it as best you can, then clean it thoroughly with Denatured Alcohol, and prime with a flat paint.
supralover72
08.26.2007, 10:43 PM
Thanks for the tip. Does it come in red?
08.27.2007, 10:11 AM
I don't know. I usually choose darker colors, so I don't remember seeing other lighter colors. I'd imagine they should.
08.27.2007, 02:00 PM
Yep, I use a fine steel wool and thoroughly scuff it up, and then wash with dish soap and water. That gets all the fine metal dust and grease (fingerprints) off the surface. I suppose denatured alcohol would work too.
JThiessen
JThiessen's Avatar
08.27.2007, 03:06 PM
Denatured Alcohol helps to make sure you've gotten rid of any residual oils, like from your fingers, and any other chemicals that may impede a good adhesion.
supralover72
08.27.2007, 03:49 PM
Thanks for the help guys!
