Traxxas CVDs, how good are they? BL worthy?
Finnster
KillaHurtz
Finnster's Avatar
Traxxas CVDs, how good are they? BL worthy? - 08.30.2007, 09:56 PM
I'm about to rip my u-joint out and went to the LHS. The stock sliders were so expensive I got the TRX CVDs instead, but I'm unsure whether to keep them, or just ebay sliders and keep replacing. They look good, but who knows. Any thoughts or experiences?
macr0w
macr0w's Avatar
08.30.2007, 10:14 PM
Are you talking centers or outboards?
I have the centers and so far they are fine.
I'm looking to get the outboard shafts as soon as they in stock somewhere.
Finnster
KillaHurtz
Finnster's Avatar
08.30.2007, 11:00 PM
The 4. They are that new then? Hmm, if the center hold up that's a good sign.
08.30.2007, 11:03 PM
I bought the cheap 6 peiceset of cvds of ebay and they are holding up fine. I think they were about 60 bucks shipped for all 6. Hang on heres a link:
http://cgi.ebay.com/Traxxas-E-Maxx-F...QQcmdZViewItem
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.31.2007, 12:07 AM
Those don't look like the Traxxas CVD's to me? The Traxxas ones have red boots, IIRC.
Finnster
KillaHurtz
Finnster's Avatar
08.31.2007, 12:10 AM
Blue boots and red anodizing. They do look sharp.
I took it as "I bought cheap ones and even they are working.."
MetalMan
MetalMan's Avatar
08.31.2007, 09:36 AM
I got the Traxxas ones for my Revo a couple months ago when they first came out. Unfortunately I did manage to break an axle on one pretty early on, and it took a couple weeks to get an axle. Since that I haven't had any problems with them, but my Revo does run a home-made "slipperential".
Finnster
KillaHurtz
Finnster's Avatar
08.31.2007, 10:43 AM
Well I went ahead and put them in the rear. They do seem quite well done. The boots are nice for holding things together and give them a spring loaded feel. They went in easy enough, however the only disappointment is that they say not to be used w/ the LT rockers, and to do the +19mm ext arms you have to buy a separate ext cup so they don't come out. I just moved the carriers to the +10mm position then. We'll see how they hold up...
cemetery gates
08.31.2007, 11:05 AM
I have them in my BL revo, they seem to hold up fine. I have ordered the traxxas extended diff outdrives to put on the rear so I can run the extended arms in the +19mm position (I have the 2.5 chassis).
Bye
08.31.2007, 11:26 AM
I tried the TRX CVDs for the Jato and broke an out-drive cup within a couple battery packs. Maybe it was a fluke, but the stockers have held up wayyy better (still on stock set). Wouldn't be so bad if you didn't have to disassemble the diff to change from CVD to sliders...
macr0w
macr0w's Avatar
08.31.2007, 07:38 PM
The 3.3 sliders are cheap enough to keep replacing I guess.
But I'm tired of twisting the ends off of them.
I'm going for some steel cvd's at some point but I don't know which ones.
I think I may get the new Traxxas ones.
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
09.01.2007, 09:18 AM
I'm using TRX centers in My E-Maxx, no signs of wear so far.
Tesla 4 president!
macr0w
macr0w's Avatar
09.02.2007, 11:43 AM
Yeah, I've had the centers for a while now. They seem to be good.
Now I'm looking at the outboard shafts.
Finnster
KillaHurtz
Finnster's Avatar
09.04.2007, 03:07 PM
Didn't get a chance to run it this wkend, but got the rears installed and it went easy enough. The CVDs only wiegh 6g ea more than the stockers btw. not too bad. : )
benjakas
09.09.2007, 08:22 AM
Don't trust the paint on the pins, use threadlock. I lost one of the cups and broke the pin on the shaft. Checked all the pins in the cups afterwards and sure enough, one of was also loose.
