FLM Hybrid bulkhead bearings
Ninmaxx
FLM Hybrid bulkhead bearings -
11.11.2007, 06:32 PM
What bearings fit in FLM's Hybrid bulkheads?
Ninmaxx
Find all posts by Ninmaxx
2
tashpop
11.11.2007, 08:34 PM
i'm not sure on the exact size, but every 1/8th diff i had laying around had the correct bearing in it, so what ever they use.
tashpop
Find all posts by tashpop
3
Ninmaxx
11.11.2007, 09:57 PM
So I'm guessing HB bearings, thanks.
Ninmaxx
4
Duster_360
11.11.2007, 10:54 PM
8 x 16 x 5mm brgs were the correct size for a set of UE style diffs. The hybrid cases are sized for 16mm OD brgs that are 5mm thick. The other dimension depends of pinion and diff output shaft sizes. Mine were 8mm od shafts.
Duster_360
Linear Mode
Switch to Threaded Mode
