Novak HV won't Work in new E-maxx
austinmaxx
Novak HV won't Work in new E-maxx - 12.20.2007, 07:07 PM
when you try to slide the pinion on the HV motor to line up with the spur the motor shaft is not long enough...the new e-maxx has more space between the spur and motor now..., a pinion that has a longer shaft might work ,,,here is a link to 5mm long shank pinions http://www.megamotorusa.com/ look under new stuff and scroll down
Any ideas?
