fan mounting for mm esc
fan mounting for mm esc -
01.04.2008, 11:33 PM
does anyone have any good ideas to mount the fan above the esc so it STAYS PUT?
Find all posts by magman
2
01.04.2008, 11:35 PM
m3 screws directly between the fins on the heatsink. Go slowly and the screw will cut its own threads. Never had a fan fall off when mounted that way. It also helps to space the fan off the heatsink 1/4" or so, helps with air flow.
Alot of Savage parts for sale!!!
Find all posts by lincpimp
3
01.04.2008, 11:49 PM
what's the best way to space off the fan?
4
ssspconcepts
01.04.2008, 11:52 PM
Never tried it, but it seems that rubber fuel tubing cut to size would work good as spacers.
BTW...the 25mm novak fans fit perfect on the MM.
ssspconcepts
Visit ssspconcepts's homepage!
Find all posts by ssspconcepts
5
01.04.2008, 11:55 PM
thanks for the tips
Hybrid Mode
Switch to Threaded Mode
