Can't get MGM controller to be seen by PC, what did RCMike do?
Finnster
KillaHurtz
Finnster's Avatar
Can't get MGM controller to be seen by PC, what did RCMike do? - 10.28.2007, 12:46 PM
I finally managed to track down a CC-02 cable, and upon plugging in my controller into the USBCom and into the PC I was greeted w/ nothing. I installed the software fine, and the computer seems to find the USBCom module ok, but the Controller program just says "controller is offline" when I plug it in. I can't really tell if the LED lights up on the ESC either (if its supposed to). The cable is fully into the ICS plug. Leds on the usb com do flash, but god knows what they mean. (they do not flash when the esc is not plugged into the USBcom/PC, so it must see something right?)
I've followed the instructions MGM provides [opto ver]. I've tried as many combos of batteries/rx/ ubec turned off and on as I can think of, but the software is a no-go.
I know mike had some probs w/ the USBcom for quite a while which were PC settings related, but I do not see any adjustments to make in the controller software. It only gives "com 1" as a com port option, and the usb device tab does list the usb device and serial #, but no adj either. I've re-installed the software a few times now.
Anyone else get this to work? I never had any probs w/ usb interfaces w/ my MM controller, nor the USB interface w/ my TP 1010C charger. I don't even see what to change to make it work (like going to Com 2, etc.) Help!
