mamba 25 on 4s?
mamba 25 on 4s? - 02.11.2008, 10:32 PM
will it work?
nitrorube
nitrorube's Avatar
02.11.2008, 11:45 PM
i dont think so,i had a mini t with a mamba 25 and with a 3cell it would get hot,just my opinion but im going to guess no
02.11.2008, 11:46 PM
not going to use that motor, just the esc.
johnrobholmes
johnrobholmes's Avatar
02.12.2008, 12:00 AM
Sure it will work, until you get a motor that is too hot. What motor, what setup?
02.12.2008, 12:01 AM
hacker 3700kv motor. gearing undecided. want about 30-35mph, be going in a kyosho half eight.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.12.2008, 12:02 AM
what mini?
rcm xt8
rcm xb8
rcm crt.5
02.12.2008, 12:03 AM
kyosho mini inferno, its 1/16 4wd buggy
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.12.2008, 12:21 AM
oh... I can't believe I didn't see it the first time.
anyways, even 30-35 is no problem with the 3700kv. you can do that on 3s with mild gearing. On 4s, you're going to be in the 40 mph range with normal gearing.
I run the same motor on 2s & 3s in a M18T. I'm geared at 14/54 right now, and I'm guessing low 20's on 2s and low 30's on 3s. These are perfect numbers for mini racing... unless you're on a 1/10th scale track.
rcm xt8
rcm xb8
rcm crt.5
johnrobholmes
02.12.2008, 11:37 AM
I would keep with 3s honestly. In anything but a tiny 1/18th you will be pushing it really hard on 4s. If you want 4s you should step up to a larger ESC, the m25 just gets hot on that high of a voltage.
02.12.2008, 12:06 PM
4s may be too much for the internal bec, so 3s may be a better choice. Unless you want to run a ccbec, but that seems overkill in a 1/16 buggy. Unless you have the batteries laying around. That hacker motor is nice, I had one in a minit for a while and ran on 3s!
02.12.2008, 08:43 PM
well any esc suggestions then? quark 65 perhaps?
02.12.2008, 08:46 PM
decided on the quark 33a.
02.12.2008, 09:04 PM
Good choice, it is an excellent esc. I have run way more than 33 amps thru mine and it did not skip a beat!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.12.2008, 09:12 PM
My quark stutters on 2s in a mini t. I can't figure it out. I thought it was just a bad quality battery. I now have a better lipo in it and it still stutters.
02.12.2008, 10:20 PM
Do you have dirty or loose motor to esc connectors? Try hard wiring and see if that helps. Or maybe your deans connector is dirty?
