1515 1.5d in an 8ight
AP Alex
AP Alex's Avatar
1515 1.5d in an 8ight - 04.04.2008, 12:56 PM
What do you think about running a 1515 1.5d in a buggy? I will be running 4s and 5s. What gearing do you recommend?
Happywing
04.04.2008, 06:11 PM
I think it will work just fine. It's kind of big for a buggy, but it'll work. Geared 11/46 on 4s should work good.
Too big?
ilpufxit
ilpufxit's Avatar
Too big? - 04.04.2008, 07:34 PM
I run a 1512 2.5d in my 8ight on 5s. Jaw dropping fast. Runs over 35 min on a 4000 mah pack and never gets hot. Geared 14/46.
Happywing
04.05.2008, 09:19 AM
I'm not sure what that has to do with the question. The 1512 is smaller and better suited for a buggy than the 1515, so that all makes sense. A 35 minute run on a 4k pack doesn't, but that's probably not under race conditions.
04.05.2008, 09:40 AM
35mins with a 5s 4k pack is not unheard of. He is running about 40mph top speed. Most likely not raceing it though.
Off topic
ilpufxit
ilpufxit's Avatar
Off topic - 04.05.2008, 11:37 AM
I'm just mentioning a setup I'm really happy with. I have to admit I'm still trying get my little brain around Neu's designations.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.05.2008, 02:32 PM
This is a reminder... please include the kv specs of whatever motor you are asking questions about. It makes it easier for everyone who responds, so we don't all have to dig and find the kv.
FWIW, I normally keep a tab open to Neu's site and link to Feigao specs because I can't memorize specs of every motor.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
I'm sorry
AP Alex
AP Alex's Avatar
I'm sorry - 04.05.2008, 04:58 PM
The Neu 1515 1.5d is a 2700kv motor. I'm have a 12t, 14t, and 16t pinion and the spur is 48t.
Fast5sRevo88
04.09.2008, 01:43 PM
This may not be relevent, but i run a feigo 8xl with a 5s 6000mah on my revo and get 30 minute run times and i drive the HEdoublehockeysticks out of it
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
04.06.2008, 08:34 PM
I think you would be better of with a 1512 1Y. It has the same kv as the 1515 1.5D, but it will not pull as much current.
Area 52 Ranch Raceway
T.R.C.R.
glassdoctor
TEAM FUSION
04.06.2008, 08:40 PM
I've run a 1515 in my buggy and it seems to do just fine. Runtime and temps are very good. Mine is only 1700kv btw and I would race with a 46 spur and 14-16 pinions.
Gearing really depends on what you are doing... but I would guess 10-12t is where to be for racing. It should be fast with the 12 and just ballistic with the bigger gears, although it should not have any problem with pulling that gearing if the batts can handle it.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Batteries
AP Alex
AP Alex's Avatar
Batteries - 04.06.2008, 09:50 PM
The batteries I will be running are polyquest 4s 6000 mah and polyquest 5s 5000 mah. I hope these will do the job.
glassdoctor
TEAM FUSION
04.07.2008, 12:43 AM
5s will crank that motor for sure lol
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Happywing
04.08.2008, 07:35 AM
You're not going to like the 5s unless you're traveling in a straight line. That's way to much for racing. Fun for bashing, I guess.
VintageMA
VintageMA's Avatar
04.09.2008, 02:41 PM
IMHO I think 5S is too much for that motor in a buggy. You're talking ~47000rpm, which the motor can do, but you'll be way past the efficiency range and there will be a lot of AMP draw getting it up to speed.
“Everyone has a right to be stupid; some people just abuse the privilege.”
