Capacitor Board?
Pedebeater
Pedebeater's Avatar
Capacitor Board? - 04.18.2008, 10:35 PM
I plan on making a capacitor board soon. I would like to know what influence different uf ratings would have. I currenty have six 330uf 50v caps, will that do? The continuos amp rating of the esc I will be doing about 98amps. The internal caps are 50v 220uf (not completly sure).
Thanks for all of your help.
Faster than a cheetah on cocaine
  Send a message via AIM to Pedebeater
04.18.2008, 10:46 PM
Just wire all of them in parallel... to get 2000uf....
04.19.2008, 12:37 AM
Just be aware that the more capacitance (and voltage) you have, the larger the initial battery hookup spark...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.19.2008, 01:26 AM
I've got a 10,000 uF cap on my MGM and it makes a little arc weld on the bullet connector each time I plug it in... Talk about punch! Unfortunately there's no way to get around that fact and still have the performance of a larger cap.
Patrick
Patrick's Avatar
04.19.2008, 11:19 AM
You must not have seen the thread about it a month or 2 ago, and the page that appeared shortly after. http://www.scriptasylum.com/rc_speed/_nospark.html
What's_nitro?
04.20.2008, 01:24 AM
No I hadn't seen it! (smacks himself for not thinking of it first) Thanks Patrick. Also, I found out I need a 600W power supply to charge my coilgun's capacitor bank in 10 seconds!
brushlessboy16
brushlessboy16's Avatar
04.20.2008, 05:28 PM
U should have looked at my thread PedeBeater, these guys said the exact same thing....
anyways here is my capacitor board
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.20.2008, 05:44 PM
Here is what i did last summer with my Quark 125.... It's very overkill I know, but that thing could handle ANYTHING i threw at it, massive over gearing, you name it.
ID:	4434   Click image for larger version
ID:	4435   Click image for larger version
chilledoutuk
04.19.2008, 10:55 AM
there is actually i used to have a resistor connected to my positive bullet connector and touch that onto the connection first to charge the cap and then connect the bullet after it worked nicely for me.
GriffinRU
04.19.2008, 10:56 AM
What for?...
When you building bank of Caps, most important parameter is internal resistance (L, C will play later). 98 Amps has nothing to do with your setup, otherwise none of this caps will handle this.
So, what is your goal?
04.19.2008, 08:13 PM
Yeah, with all the HV setups popping up, I thought we'd see more "how do I get rid of the spark" type of threads.
Pedebeater
Pedebeater's Avatar
04.19.2008, 09:33 PM
I just want to make a capacitor board for my upcoming hacker master car sport esc, just for more punch. Will I damage anything by using higher uf caps?
GriffinRU
04.19.2008, 11:37 PM
Just add one 800-1000uF 35V FM series cap.
In general should be no damage but all depends how you going to put it together.
Short wires, good connectors all what you need.
