1/8 Buggy Tire/Wheel weight?
cmcclive
1/8 Buggy Tire/Wheel weight? - 04.23.2008, 08:15 AM
Ok humor me here...
In an effort to save money I bought some cheap tires off of ebay. They work great so far, but when I put them on a scale I was surprised to see that they weighed around 1 lb for the set of 4.
Is this normal?
As my buggy is overweight, I would consider paying for pro-line or other brand name tires/rims if there is enough of a weight savings.
So, If you have any buggy tires around I would appreciate it if you could throw it (1, 2, or 4) on a scale and let me know how much it weights.
please include:
Number of tires-
Tire brand/model-
Rim brand/type (type=dish/spoke, ect)-
if you are aware whether they are soft or medium compound that would be helpful
Also, include how much wear the tires have seen (if they are bald, they should be slightly lighter).
Additionally, does anyone know if the molded foam inserts are lighter or heavier then the old school donut foams?
I know I touched on this in a pervious thread a month ago, but I didn't get any solid numbers, and I feel this might be useful to others in the future.
Thanks
bdebde
That's All Folks!
bdebde's Avatar
04.23.2008, 09:14 AM
Panther switch tires (soft, with included foams) on Ofna spoke rims = 13 3/4 oz. set of 4
david lamontagn
04.23.2008, 04:57 PM
13 3/4 = 0.859375 lbs
Do you realy thing cmcclive that this 0.140625 lbs difference will help your buggy to accelerate faster
cmcclive
04.24.2008, 07:19 AM
David,
I am more interested in reducing weight to put less strain on the motor. The buggy is at 9.3 lbs, there is fat to be cut, I want to find out where. I know there are several things I could do to cut weight more drastically, but I also want to fully evaluate all possibilities before going further. Also, looking at the data below, my tires are actually 1.09-1.1lbs, while his were .86lbs, that might be enough of a difference for me to care, especially sense that is rotating mass, that has much more effect then say the same weight difference on something "stationary" like the batteries.
Definition of stationary in that example-object that does not move relative the buggy.
And to update my tires:
Weight-1.1lb(499.7g)
Number of tires- 4
Tire brand-unknown
model-"racing spikes" (see here)please note: this link goes to an ebay page, it is not my ebay page, but it is the product I purchased, I am not endorsing this product or trying to sell it to you.
Rim brand-unknown
Type (type=dish/spoke, ect)-Dish
Rubber-medium compound
Condition-New
Weight-1.09lb(494.5g)
Number of tires- 4
Tire brand-unknown
model-"Mohawk" (see here)please note: this link goes to an ebay page, it is not my ebay page, but it is the product I purchased, I am not endorsing this product or trying to sell it to you.
Rim brand-unknown
Type (type=dish/spoke, ect)-Spoke
Condition-99.9% new (no wear)
If my post is confusing I apologize, I just sat in a 6-8 room for 8 hours watching iron pellets come out of a tube (more complicated then that obviously). Now I have to work another 6ish hours before I go home and start the process again tonight. AKA I am not necessarily in the correct frame of mind.
david lamontagn
04.24.2008, 08:22 AM
What's your buggy??
I'm to convert my Hyper 7 pro, and with the 1515 motor, the FP 5000, 4s pack and MGM 16018, i'am to 8.6 lbs.
It's a prety heavy buggy. I would want to have an MBX5R, but don't have $$$ for this now.
But 8.6 lbs is lighter than my mugen truggy at 11 lbs
cmcclive
04.24.2008, 08:41 AM
my buggy is a mp777 sp2 with a novak HV4.5 motor, 2 aluminum battery trays and (the biggest weight issue) 2 2s 10,000mAh lipo batteries.
I decided to go with the huge batteries to ensure I could survive the 15-20min A-mains at the local nitro track, as well as bash for ever. Although going with say a 5000mAh battery would have cut .8lbs off of the weight of the buggy, I didn't know for sure if it would give me enough runtime. (On occasion, if someone needs to leave by a certain time I have seen them run the race right after that classes 2nd qualifying, which would add 5 minutes onto run time.
Cost effectively, if I refuse to cut down on the batteries the wheels (if I can find something a little lighter then those 0.86lb wheels that aren't to expensive) are one of the few things left for me to cut down on, other then maybe remaking my battery trays from UHMWPE or derlin. Or changing motor/esc as the novak system is heavy.
I do need to run the buggy more, once I rebuild the diff to see if my motor thermaling was a fluke (I was running in grass) or if it will actually keep happening as thermaling is just as bad as dead batteries in a race...
I could try to put another fan or two on the motor... or maybe buy novak's new fan mount thing as I am pretty sure it would save weight
Here is a pic of my buggy, other pics are on my "mp777 sp2 brushless" thread
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.23.2008, 09:17 AM
Also need to list the foams used.. and if they are clean ;)
I can weigh some sets late tonight..
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
cmcclive
04.23.2008, 09:42 AM
thanks for the info (and keep it coming). I might need to bring my tires to work tomorrow to get a better weight then "about a pound" so that we can better compare of no-brand tires to brand name.
nl12
nl12's Avatar
05.11.2008, 10:07 AM
I would like to know the weight of all the proline premounts
