giving up on mamba monster
dpb318
giving up on mamba monster - 05.23.2008, 11:31 AM
I know many people have run a mm with 4s successfully. Does anyone have any reports of one dying on 4s? I really don't want to get this thing and then fry it if I bash hard. Im going to be running a 9xl with it (in a Savage)
05.23.2008, 11:41 AM
The issues uncovered thus far are not voltage-related, but from either a bad batch of a specific component, or the fan.
As long as you keep the current within the ESC specs, it shouldn't fry.
crazyjr
crazyjr's Avatar
05.23.2008, 12:15 PM
I find this, a bit funny. Everyone was mad, because they took their time, Now everyone is mad at castle because of something they can't control. What happened to the acceptable amount of defects? Everyone expects perfection. I wouldn't worry about a few BEC failures, castle has the best support
dpb318
05.23.2008, 05:49 PM
im not giving up because the mmm doesnt work, i just thought id go for a mm since im not running above 4s...and the mmm is still out of stock like everywhere
Crt-Racer
05.25.2008, 07:27 AM
I received my MMM from impaktrc in about 2 weeks, there in stock
Mozzy
Mozzy's Avatar
05.25.2008, 12:57 AM
Finedesign has them & for only $170.
Well, they did last time I checked.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
Sammus
Sammus's Avatar
05.25.2008, 07:38 AM
pretty hard to go past bpp's mmax for $114 free delivery :) speccy if u live on the other side of the world like me :)
05.25.2008, 09:58 AM
Are you going to leave the 2 speed and mech brakes in the savvy? If so the MM should work fine. You will need an external bec, like the ccbec, and remove the red rec wire on the MM to disable the internal bec. Depending on how much airflow you have inside the body, you may need a fan on the MM. Otherwise they are a decent esc for 4s usage. Plus you cannot beat the price and versatility!
Mozzy
Mozzy's Avatar
05.27.2008, 09:39 AM
My Mamba Monster died today. As far as I was aware it is more than capable of running a Neu 1515/1.5D/2700Kv on a 4s.
It was running fine all day till the arvo & it just went dead, not even the fan works. Checked all wiring & nothing's loose or broken.
Do I send it back or just bin it?
What would you do? Anyone?
05.27.2008, 09:46 AM
If it just died with no burnt smell or smoke, it sounds like you have one of the ones with the faulty BEC. Give Castle a call and they'll set you up.
Mozzy
Mozzy's Avatar
05.27.2008, 10:27 AM
I didn't see smoke, but, it has a very slight smell.
Maybe the fan?
What a hassle to return. Oh well, lucky I have another one while this goes back.
brushlessboy16
brushlessboy16's Avatar
05.27.2008, 10:36 AM
I run mine on 5s all the time, runs cool with a 600 kv outrunner
Mozzy
Mozzy's Avatar
05.27.2008, 10:52 AM
This Neu is rated for 120amps, but, the battery could only supply 76amps. If anything went it should've been the battery, right?
Sammus
Sammus's Avatar
05.27.2008, 06:44 PM
If you have a look at the castle creations section on this forum you'll notice that the first run of mamba monsters had a higher failure rate because a faulty component in the bec or something, its not because you over loaded it or anything.
If you're gunna chuck it in the bin, I'll pay the postage and you can give it to me instead, I'd be more than happy to pay another $20 registered insured postage from australia to kansas for castle to replace it no questions...
tc3_racer_001
tc3_racer_001's Avatar
05.28.2008, 01:38 AM
hehe, nice try!
ill pay $50 for it...
anyway. didnt castle mention that weak batteries can drain the caps and cause backflow or something and ruin it that way? they recommend a minimum of 75A cont. so 76 is very fine. id suggest going with 100A just to be safe :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
