Your opinions...
Steve Krug
Steve Krug's Avatar
Your opinions... - 06.03.2008, 08:46 PM
First off, this is rustlerboi1052 on all other forums BTW...
Been doing alot of research on my MBX5-T electric conversion and I don't feel like waiting another 2 months for my MMM. It seems like there are still bugs in the MMM to work out, and i'd just hate to keep waiting. This has been on my mind for awhile now already.
Anyways I was thinking about running a MM speedo with the castle BEC instead. I'd be only running 4S lipos with...i'm not sure what motor yet. Is the performance good with the MM and the 4S, or will it burn up most likely? And what modifications do you do to the speedo in order to attain the capabilities of running a 4S lipo without burning up? I'm just bashing for now, but there is a possiblity I will race this setup.
Also, what decent motor do you guys suggest that will run very well with a
4S lipo? I want something with power like the Neus, but not that expensive. My budget isn't anywhere NEAR that of a Neu, although I'd kill to have one.
Just want your opinions on everything.
Thanks in advance,
steve
rootar
rootar's Avatar
06.03.2008, 09:02 PM
i believe everyone is liking the medusa 60mm motors they are twice as expensive as a feiago xl but only half the price of the neu and are inbetween in performance also.
azjc
06.03.2008, 09:14 PM
if you are having budget constraints I would go with a L can feigao I get good results with a 9L and MM ESC in a Rustler
dirt101
dirt101's Avatar
06.03.2008, 09:21 PM
I wouldnt use an L can, you will see severe overheating
Steve Krug
Steve Krug's Avatar
06.03.2008, 09:30 PM
I've heard about the Medusa's, somebody told me the 60mm motor will be slightly small for a truggy, and will heat up also...And the highest KV rated motor for the Medusa 60mm is 2000kv, which I would think would be slow on a 4S lipo...
azjc
06.03.2008, 09:41 PM
oh..its a truggy I thought it was a buggy I would go with a 8XL than just under 2100kv..avg price for one is $80
skellyo
skellyo's Avatar
06.03.2008, 09:52 PM
If it were the MBX5 (Buggy), the 9L would be a decent choice on a budget. While it will run a little warmer than an XL can setup, it still performs well on 4S. I've run a 9L for a bit in my MBX5 with good results.
Steve Krug
Steve Krug's Avatar
06.03.2008, 09:32 PM
Whooops, also, anybody by chance have and used gear they can sell for cheap? I'm a HS student just so you know that I can't afford much LOL.
entjoles
06.03.2008, 09:57 PM
i have a heatsink/clamp for xl series motors i will give you
i have ran 4s and 5s in my mm and it does very well, 4s for track use should be fine with a 8xl
the mm "should be fine" but as with any component check temps and gear accordingly
Steve Krug
Steve Krug's Avatar
06.03.2008, 10:30 PM
I may put my order in now...
Feigao/Nemesis/Wanderer "XL" Brushless Motor $80.00 $80.00
wanderer xl wind: - 8xl - -
Electric Motor mount for Mugen $55.00 $55.00
5mm bore, mod1 pinion $12.00 $12.00
pinion size - mod1 -5mm: - 13 tooth hardened steel - -
Castle Creations Mamba Max ESC $137.00 $137.00
Castle Creations 10 amp Switching BEC $22.00 $22.00
Sub Total: $306.00 Delete
Shipping Estimate: $9.79
Grand Total: $315.79
And my gosh 15 bucks over the amount i've got, meh.
entjoles,
Seriously??!?! That would be so incredibly awesomely awesome. You can't imagine how much that'd help. I see you live in MN? Where you located? I'm in SW Minneapolis lol.
entjoles
06.03.2008, 11:06 PM
i live in eden prairie, and yes you can have it , i have no use for it and you seem like the right person to get it
steve krug.....pm me your address and ill try to get it out by the end of the week, no cost to you
BlackedOutREVO
06.03.2008, 11:03 PM
Good to see you over here man!
Sounds like a good list, you can always swap to something nicer if needed, but still BL is way better then nitro! Haha
Still going for True rc lipos, or no?
Steve Krug
Steve Krug's Avatar
06.03.2008, 11:05 PM
I WAS going for truerc lipos until I found out they are out of stock with ALL of their 4S lipos. I have a feeling members from here bought all of them LOL.
BlackedOutREVO
06.03.2008, 11:11 PM
Haha yeah, true rc packs arent always in stock, there a darn good deal for what they are for sure!
jnev
jnev's Avatar
That is an awfully kind thing for you to do entjoles.
Welcome Steve! You may want to try emailing or calling TrueRC. Often times, they don't have time to update the webpage once they restock their stuff...
