CastleLink MM Issue! "Please Help"
Takedown
WARNING: May become violent.
Takedown's Avatar
CastleLink MM Issue! "Please Help" - 07.11.2008, 07:24 PM
My friend BL_RV0 here on the RCM forums says he cant program his MM threw castlelink on his comp and couldnt program his previous MM either. Is their anyway he can get around this issue? Could it be a bug? He says he's tried two comps and two MM's with the same castle link and nothing... All help would be greatly appreciated.
RIP- Tammy (9/14/08)
tc3_racer_001
tc3_racer_001's Avatar
07.11.2008, 07:35 PM
with the same castle link is this a mamba or monster max? if its a MMM then try a different castle link, thats all i can say, if its a mamba max then try disabling anything which may control or take over the usb ports and firewalls (preventing certain functions possibly needed?) and trying that.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
azjc
07.11.2008, 07:39 PM
when he connects the esc to the computer does he get the conection "green squares" in the bottom left of the program box, if not try moving the switch tha t come swith the esc
Takedown
Takedown's Avatar
07.11.2008, 07:41 PM
Thats what I thought it was... Theirs something blocking the usb ports.
07.11.2008, 07:48 PM
I get red connection squares.... The power switch on the esc is broken, so I can't do that. Now, I shredded one of Mike's bore reducers... I'd take a pic but can't find my camera. God this ST is a nightmare.
azjc
07.11.2008, 09:05 PM
so you are not even getting a USB connection than the switch wouldnt matter...have you tried all of your USB ports?
tc3_racer_001
07.11.2008, 09:27 PM
are they 2.0 usb? what computer are you using, and do you have any illegal content (programs etc) which may affect the computer? (someone i know had an illegal copy of windows and wondered why it crashed every time the automatic updater ran
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Takedown
Takedown's Avatar
07.11.2008, 07:49 PM
The CC power switches are really brittle... I say just direct solder the positive and negative leads on the baord toghether or solder the positive and negative wire off the switch toghether.
07.11.2008, 07:51 PM
I had the same on my company laptop - Ended up doing a clean XP install and then it worked fine...
Takedown
Takedown's Avatar
07.11.2008, 07:59 PM
BL_RV0 you should try all these suggestions.
brushlessboy16
brushlessboy16's Avatar
07.11.2008, 10:39 PM
Is he running Vista?
azjc
07.11.2008, 10:54 PM
I am running Vista and I had to run the program as "the administrator"
brushlessboy16
07.11.2008, 11:11 PM
same
asheck
07.11.2008, 11:29 PM
Mine will not run right with vista no matter what I do.Well I can load it and it works,but it puts an error message on my screen,thats says this program will not work with Vista.If I click it it unloads the program,if i just leave it alone then it lets me run it just by clicking the icon.But everytime my computer gets turned off it unloads.
