How is Hobbycity's UBEC?
chumanji
How is Hobbycity's UBEC? - 07.18.2008, 06:21 PM
Anyone use one of these UBEC before. Price seems to be very good.
http://www.hobbycity.com/hobbycity/s...oise_Reduction
07.18.2008, 06:54 PM
Might ask maneba as it looks like he is using that exact one:
http://rc-monster.com/forum/showthread.php?p=192696
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
07.18.2008, 07:03 PM
I use one of those units (not branded "Turnigy", but identical) and I've not got any complaints. It outputs around 5.9V when the jumper's in 6V mode, which sometimes dips to around 5.8V when it's under heavy load. Runs cool though, and it's reliable too. The output/input wires could do with being a tad heavier gauge, but it's not caused any problems for me. Well worth the price if you don't need a higher-performance UBEC, IMO.
junkman
07.18.2008, 08:50 PM
I've ran them on several cars, they work like they should, and are cheap. My only concern is, that I get more glitching with them than without. I have 4 or 5 of them. I have a bad rf problem around my house for some reason I havn't pinned down yet. It doesn't affect brushed cars, but pretty much all the brushless ones do it.
07.18.2008, 09:57 PM
I have a few, and they work fine. They are a bit noisy, and I have had to move them around on the chassis to cure glitching. The ccbec is better, although it has its own issues if it fails (cooking receiver and servos).
Not bad for the price, and I have never had the turnigy fail on me...
Desmo
07.18.2008, 10:43 PM
I have one in my Elst. No problems yet and its in the radio box right next to the receiver.
azjc
07.19.2008, 03:48 AM
my only concern would be if the unit fails would it still allow current to pass....if it does I wouldnt use it, you could lose your Rx and servos if it does
chumanji
07.19.2008, 05:16 AM
I had the exact same concern. My castle one failed on me and cook both servos...ouch$$$.
Serum
Serum's Avatar
07.19.2008, 05:44 AM
Wothless. Mine thermalled within 2400mAh of running.
Not good at all. Go for the castlecreations.
Desmo
07.19.2008, 11:33 AM
How many servos are you running? I only have one airtronics 94359z and it dosen't heat up.
07.19.2008, 12:32 PM
FWIW, my personal favorites in testing are the KoolFlight UBEC and the Hercules UBEC for amperage ~3A. For lower amperages, the DimensionEngineering UBEC is really nice. All three of these had no discernable noise, high efficiency, and heat was respectable.
The CC BEC is king for currents >3A and programmability. But as others have said, the fact that it outputs full V on failure is a little worrisome IMO.
azjc
07.19.2008, 02:02 PM
here is a link to what I am using its a little pricey and overkill, but I have $250 invested between the Rx and steering servo and I would be pissed if they fried, its worth the extra $25 for a quality BEC
http://www.helidirect.com/product_in...oducts_id=4667
07.19.2008, 02:35 PM
That's the one I'm using in my Ultra GTP because I plan to run 8-10s. It tested great, but have yet to use it in real world conditions.
chumanji
07.20.2008, 06:00 AM
Does anyone know...If this Hobbycity UBEC fails. Does it pass the entire voltage through like the CC or does it just cut the power?
Dagger Thrasher
07.20.2008, 12:05 PM
I'm not sure...mine's never failed. To be honest though, as long as you don't push it over its rated specs, then there's no reason why it should fail...especially with it having a thermal shutdown circuit. Like I say, I've been using one for about a year now with no problems whatsoever. I've also never had any noise problems either, though I'm on 2.4Ghz. If you're powering particularly expensive radio kit from it though, it's understandable to want to spend a bit more.
