Zippy-R Pack dimensions
E-Traxxer
Zippy-R Pack dimensions - 08.04.2008, 08:20 PM
Hey everyone, I have a question about the Zippy-R packs. I know on HobbyCity it says the packs are 170mm long, but are they really that in the real world? Because I know that when I got my TP packs, it was stated that they were 160mm in length, but in the real world when I got them they measured more like 165... So does anyone know if the Zippy-Rs are really 170mm? I don't want to drop $200+ on three packs if they are going to be too long.
Thanks!
spaz163
Functionality with a dash of Form
spaz163's Avatar
08.04.2008, 09:45 PM
Well it depends where you measure to. I just went and measured mine and I came up with 165mm (6.5") if you measure from the end of the pack to in between the balance and charge plugs. But if I measure from the end of the pack to the end of the shrink wrap around the charge plug leads I get 177mm (7").
So if you were using a low tray so that the balance and charge leads could just hang over the end of the tray, I would say 165mm and then use a velcro strap down the length of the pack in between the 2 plugs.
I have not been able to run this pack yet because of a faulty charger I recieved so I cannot give you any performance data on it yet. Oh and I have the 4s 4800 Zippy-R.
E-Traxxer
08.04.2008, 10:06 PM
Thanks, that's the exact answer I was looking for.
It sounds like they are the exact dimensions of my TP packs. I am also going to be getting the 4s 4800mah. :)
Thanks again.
tc3_racer_001
tc3_racer_001's Avatar
08.05.2008, 03:08 AM
so will this fit in a tray designed for the new enderland packs? (168mm compared to zippy's 170mm... personally i think they are using similar cells.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
ffactory666
08.05.2008, 03:48 AM
Wont fit because they are 50m wide.
I just had Mike make me two custom trays so i could fit my new PQ pack ( Enelrand cells ) and Zippy packs.
E-Traxxer
08.05.2008, 04:19 AM
The Zippy-Rs are stated to be 45mm wide...
Are they really 50mm?
ffactory666
08.05.2008, 06:34 AM
My bad , sorry . Mine are the H packs not R
Byte
08.07.2008, 03:58 AM
So, you measured till the blue stripe, right? That was 165mm? But can you say me the length of the pack from the end to that black cell? ( Look picture )
Ty in advance!
E-Traxxer
08.07.2008, 04:07 AM
Ty in advance!
I'm fairly sure that he meant that the red stripe was 165mm long, and to the blue stripe it was 177mm long.
Byte
08.07.2008, 04:14 AM
Ok ty!
Sorry, but my Englisch is not that good..
Anyway.. It won't fit in my E-Firestorm or Rustler VXL :(
spaz163
spaz163's Avatar
08.07.2008, 06:05 AM
From the end of the pack to where you can see that black stuff in between the two leads, I measured 165mm. But from the end of the pack to where you have your blue line drawn, I measured 177mm.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.01.2008, 11:43 PM
Has anyone tried cramming a 4800mah 3s zippy-r into an e-revo?
skellyo
skellyo's Avatar
10.02.2008, 09:47 AM
A couple of reviews from the hobbycity site regarding the 3S 4800mAh pack:
"I use it on my Traxxas E-revo in combination with a 36-74-1900kv motor. It fits perfectly with no modifications. At this price, it is way better than most of what's available. Highly recommended."
"Use it on my e-revo. it fit without any problem. Does not come with any plug, so I put deans on them. The wires are very thick, indicating they should put out some serious power."
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.02.2008, 04:01 PM
Thank you, guess I should have opened my eyes a little when I was looking at them!
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.02.2008, 07:55 PM
I did. But needed to cut the doors a bit to get the 8g wires to run out of them.
The batteries fit fine themselves, but the wires coming off of them are HUGE.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
