What's wrong here? Now with video!
e-mikey
What's wrong here? Now with video! - 08.17.2008, 10:39 PM
After this little video (and a short one after it) all connectors are hot to the touch, the motor was very hot, and the esc was hot. All from like 10 seconds. When I take the motor off the spur, it spins fine.
I had something like this happen before, it turned out to be bad solder on the bullet. I checked the this time, one was loose so I soldered it better.
brushlessboy16
brushlessboy16's Avatar
08.17.2008, 10:42 PM
sounds like cogging, try bumping up your start power
e-mikey
08.17.2008, 10:48 PM
I'll try it right now, weird that it's been working for so long, then all of a sudden...
brushlessboy16
08.17.2008, 10:49 PM
did you recently change gearing?
e-mikey
08.17.2008, 10:57 PM
I have been changing pinons a lot, yes. But no pinions I haven't already tried. Set screw is tight if that's what your thinking.
brushlessboy16
08.17.2008, 10:59 PM
that is probably why, making the motor turn the wheels further per rotation, more load
remember your testing wihtout any airflow over the esc
did the problem clear up?
e-mikey
negative.. I tried medium, then high. It's amazing how quick it all heats up.
e-mikey
08.17.2008, 11:00 PM
In that video the throttle was pinned.
e-mikey
08.17.2008, 11:01 PM
no. it's been like this since 6pm. The motor did get blistering hot with the 20t pinion earlier today.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.17.2008, 11:53 PM
If the motor got blistering hot it sounds like you may have demagged your rotor.
e-mikey
08.17.2008, 11:55 PM
Anyway to tell for sure?
brushlessboy16
08.17.2008, 11:03 PM
hmm check the windings of your motor
e-mikey
How do I do that? This motor has no screws to open it up.
TruckBasher
TruckBasher's Avatar
08.17.2008, 11:13 PM
Hard to see from the video but before the truck rolled forward was the spur rotating or just trying to rotate like going back and forth? If so you might want to check connection between motor and ESC it seems 1 phase is not working/connected properly.
E-Slayer direct drive to diff
e-mikey
08.17.2008, 11:23 PM
I believe it's the motor. I hooked up my sidewinder and it did the same thing.
Any ideas of a next step? I feel the bullets are on there pretty good.
