newb ?
bustitup
newb ? - 09.04.2008, 12:50 PM
can someone show me a diagram on how to use a rx pack instead of an external or internal bec
brushlessboy16
brushlessboy16's Avatar
09.04.2008, 12:51 PM
Here you go
http://scriptasylum.com/rc_speed/_wiring.html
fill it out and it tells you how to wire it :D
George16
Supermaxx
George16's Avatar
09.04.2008, 12:53 PM
Here's another one fromBrianG:
Or just plug it directly into your rx's battery port.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
09.04.2008, 01:01 PM
DO NOT DO THIS UNLESS YOU HAVE AN OPTO ESC - YOU WILL BREAK SOMETHING.
This setup is very specific to where you want to power the esc from the rx battery as the internal ESC BEC has been removed or does not exist!
This is very unusual - normally the internal ESC's bec is still left to power the brain board and the red wire on the ESC lead must be removed!
Which ESC are you using - Brian's script is the best tool to look at.
09.04.2008, 01:50 PM
Exactly! This is a special diagram made specifically for the MMM BEC removal mod. Using a BEC and a receiver pack at the same time could cause issues.
brushlessboy16
09.04.2008, 12:58 PM
http://scriptasylum.com/rc_speed/_pi...20lvc_1.gif~18
George16
Supermaxx
George16's Avatar
09.04.2008, 01:04 PM
Bustitup, what ESC are you trying to use this for?
Revo with OS .18TZ
bustitup
09.04.2008, 01:25 PM
well the only esc I have used so far is the mm with bec I have my new mmm but havnt wired it in yet...I have been reading and it seems that you can eliminate a internal and external bec by just using a battery pack eliminating the problems with bec's especially the mmm
did I assume the wrong info here
bustitup
09.04.2008, 01:27 PM
btw.. those diagrams you guys sent me from BrianG site were fantastic.....I told him the G in his name stands for Genius...lol
bdebde
That's All Folks!
bdebde's Avatar
09.04.2008, 03:22 PM
Originally Posted by bustitup View Post
btw......I told him the G in his name stands for Genius...lol
You shouldn't have done that... his head is big enough already
09.04.2008, 03:52 PM
Funny, I always thought the G stood for Gelding...
lutach
lutach's Avatar
09.04.2008, 04:44 PM
Simple Rx pack will do. I've been using them for a long time now and trouble free. I would use a lipo Rx pack if your electronics can handle and needs that much power to work at its full potential. I would still go for a good nixx Rx pack.
09.04.2008, 01:30 PM
Mixed results - Consensus is that it can't hurt but might not help... Go with the remove the red wire diagram for the MMM...
09.04.2008, 04:56 PM
Better watch it guys, there may be warning points in store for you!
bdebde
That's All Folks!
bdebde's Avatar
09.04.2008, 05:37 PM
ooooh
