Who Still Has a Working MMM 'V1'
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Exclamation Who Still Has a Working MMM 'V1' - 09.15.2008, 05:47 PM
Just wondering who still has a working MMM V1 and what Firmware you are running? I have only changed the settings on the ESC, I have never updated the Firmware from what it is out of the box
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
09.15.2008, 05:54 PM
I have a working v1 with the original v1.17 firmware and a working v2 with v1.19 firmware.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
09.15.2008, 05:56 PM
i've got one as well...my MMMv1 is in my 8ight w/ updated firmware.....my MMMv2 is working as well in my muggy...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
e-mike
e-mike's Avatar
09.15.2008, 06:04 PM
two of my friend here have one unit ...each one still going strong
D8t on juice!!
bruce750i
bruce750i's Avatar
09.15.2008, 06:09 PM
V1 still good, box stock, 1.19 on 6s
Cowboy
09.15.2008, 07:01 PM
I have 2 that are still up and running 1.17 firmware on 6S, ccbec and fan wired to run off ccbec
gixxer
gixxer's Avatar
09.15.2008, 07:26 PM
still working in my e-revo on 6s.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
09.15.2008, 07:33 PM
Still working on 4s ATM with my mod, will go to 5s in the future.
Edumakated
09.15.2008, 08:07 PM
My first two v1's went up in smoke, but my 3rd v1 is going strong with the original firm ware. I just cut the top of the case off and run with no fan. Works great. Temps typically about 150 - 170 after a 10 or 15 minute main.
I run 5s with a Neu 1512 3d or 1515 2.5d depending on how I feel that day.
jhautz
jhautz's Avatar
09.15.2008, 08:22 PM
I have a V1 that is still working v1.17 software and It just went back into the XT8 truggy to replace the V2 that had a BEC failure. I originally pulled out of the truggy to replace it with the V2 I got in replacement for my first failed V1. Not allot of run time on it yet. Maybe 3 hours or so. My 2 other V1s lasted well past this long before the BEC died in them, so I'm still holding my breath. The V2 I had only made it an hour or 2 before the BEC went. I still have a V2 that hasn't been plugged in yet. Waiting for the V1 to go first.
to make it...
or break it...
Silent...But Deadly
RBMike
RBMike's Avatar
09.15.2008, 09:14 PM
Edumakated, Internal bec?
09.15.2008, 09:28 PM
Still have 1 v1 that works fine. Must have 1.17 firmware, as I do not remember changing it. I have played with the settings with the castle link quite a bit. Running 4s with a 1515 1.5d.
Edumakated
09.16.2008, 07:12 PM
Yup. Using the internal BEC. I also have a v2 that is holding up pretty well, but I am just going to keep using the v1. After the abuse I put it through and if it is still going strong, no need to mess up a good thing. I am going to add a cap to it to take a little pressure off since I don't have a fan on it.
For those that care about setups:
RC8
V1 MMM (top of case cut off completely, no fan)
1512 3d and 1515 2.5d
5s 4000 Zippys
Dx3r w/ Receiver
Geared for about 35-42 mph depending on track
jnev
jnev's Avatar
09.15.2008, 09:30 PM
I have a V1 MMM (with no mods) that is going strong with lots of run time on it in my 8ight. I am using the stock firmware, or whatever it came withe when I bought it.
I also have a V2 MMM (with no mods as well) that is going strong too. I had a short test with it in my 8ight, and a short test with it in my CRT.5. I will have much more testing with it in the CRT.5 this upcoming weekend.
I also plan on buying one more MMM for my 8ight-T which will be running 6s. The 8ight and CRT.5 are both running 4s at the moment... but I can't be happier with the performance of the MMM's I currently have.
Edit: If anyone cares about the set ups, I am running a Hyperion 4s 5350mah pack in the 8ight with a Hitec HS-5997MG servo and Tekno Neu 1515/1y motor geared 47/17. And the CRT.5 has a Neu 1509/1.5y motor, Flightpower 4s 4370mah lipo pack and a Hitec HS-5245MG servo geared 46/16.
auto2
09.15.2008, 09:42 PM
i do :-)
