Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Custom 1/4 Dragster Build
Takedown
WARNING: May become violent.
Takedown's Avatar
Custom 1/4 Dragster Build - 09.27.2008, 09:35 PM
Ive decided to pursue my biggest project yet. A 1/4 dragster. My setup will be...
Chassis, Yes a dolly... "Very modded, towing plate removed and front handle removed and rear end axle will be lowered"
Engine, 30cc CY w/ Xcan "4.8hp"
My idea was to run the rear axle threw the bearing on the lower end of the tranny and hook a gear onto the shaft with two flat spots. The whole rear end will be solid w/o suspension and the front will have suspension.
I still need help on deciding what arms, front wheels & tires & body to use along with it. It will weigh around 35lbs when fully loaded. The 30cc CY should handle that with ease. Its going to be geared for torque.
Any help with this build will be appreciated.
RIP- Tammy (9/14/08)
Takedown
Takedown's Avatar
09.27.2008, 09:38 PM
Im also thinking about running chain drive from the clutch bell gear to the solid axle gear. It would make more sense going about it this way.
plettenbergs
plettenbergs's Avatar
09.27.2008, 09:45 PM
call it the dolly lama!
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.27.2008, 09:44 PM
Ambitious I must say. Will be an interesting build none the less, unless that is of course, you change your mind..........
again, then again, and maybe at least once more.....
www.cubicle101.com
Takedown
Takedown's Avatar
Haha, knowing me I just might do that. But seriously, I cant sell the motor so I might as well put it to use and seeing how this build wont be that pricey it might be worth it.
Takedown
Takedown's Avatar
09.27.2008, 09:57 PM
But ya we'll see what it amounts to. If I buy the dolly which I probably will I will definately finish the project.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
09.27.2008, 11:24 PM
subscribed.....should be pretty cool looking....i foresee a ton of welding in your future...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
Takedown
Takedown's Avatar
09.27.2008, 11:28 PM
Their will be some welding involved for sure. I still have to test out my welding skills.
Takedown
Takedown's Avatar
09.27.2008, 11:31 PM
I think I found a welder kit...
http://www.harborfreight.com/cpi/cta...emnumber=55594
TruckBasher
TruckBasher's Avatar
09.27.2008, 11:33 PM
this is interesting.....
I bet we wont recognize the dolly once you completed the project...
E-Slayer direct drive to diff
Takedown
Takedown's Avatar
09.27.2008, 11:35 PM
I hope that its unrecognizable so that people wont be asking "hey is your chassis made from a dolly?" Its our little secret...
Takedown
Takedown's Avatar
09.27.2008, 11:47 PM
I want to know how much they would sell the body for?
http://www.neweramodels.com/item.cgi...=&part_id=1127
sikeston34m
sikeston34m's Avatar
09.28.2008, 12:08 AM
Could this be an easier alternative to the back breaking work of moving?
jayjay283
jayjay283's Avatar
09.28.2008, 12:45 AM
I was going to say you should talk to them (new era), they do that stuff alot.... and when you have it built, I have a fridge that needs moving... if you can move it 3 blocks in 3 minutes will earn you a cool c-note..
Takedown
Takedown's Avatar
09.28.2008, 12:18 AM
God, I knew you guys would make fun of me for this idea.
