Castle connector ?
rchippie
rchippie's Avatar
Castle connector ? - 11.13.2008, 10:23 PM
I just installed my castle 5.5mm connectors on my neu motor & castle esc & i noticed something. when put the two plug halfs together there is a small gap between the two ends . I pushed as hard as i could but they will not go on anymore . Has anyone else noticed this ?.
REAL MEN RUN BRUSHLESS
11.13.2008, 10:34 PM
I do not have the 5.5 but the 6.5 do not do it for me...
rchippie
rchippie's Avatar
11.13.2008, 10:37 PM
do you think i should use them or get another set ?. The gap is about 1/16th .
11.13.2008, 10:45 PM
I would get another set...
rchippie
rchippie's Avatar
11.13.2008, 10:47 PM
This blows . There a brand new set that was sealed in the bag . By the time i pay shipping a new set is going to cost close to $15.00.
11.13.2008, 11:15 PM
Check for any burrs on the plug or in the socket...
rchippie
rchippie's Avatar
11.13.2008, 11:20 PM
there are no burs . The female plug is 9.92 mm & the female plug is 10.18mm .
jhautz
jhautz's Avatar
11.14.2008, 12:29 AM
Are they all that way, or just one of them? I would think that as long as its secure and you have the full contact of the plug it shouldnt be a problem. I'd run it.
to make it...
or break it...
Silent...But Deadly
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
11.14.2008, 12:59 AM
I don't see any issue with it. I'm disappointed with the female plugs on my new v3. Most of them are extremely loose. I am going to have to spreadt the tongs on the male connectors.
bdebde
That's All Folks!
bdebde's Avatar
11.14.2008, 01:02 AM
If you are getting a good fit/connection, just re do the heat shrink and slide it up a bit.
tc3_racer_001
tc3_racer_001's Avatar
11.14.2008, 05:31 PM
MT: i was told we ARE allowed to solder the females DIRECTLY to the MALES on the MMM plugs. i have had issues with this looseness thing and when i get my new controller back i will fill the gaps up with solder. aparently the guys testing the escs have been doing this....sounds like more resistance and more of a pain than a wire!! o well...
heres the email he sent:
On the V3 MMM's the power wires are soldered directly to the circuit board. It is okay to solder the 6.5mm male bullets directly to the female bullets attached to the MMM. This will NOT void your warranty, I have confirmed this with the engineers; they have actually done so themselves on several occasions. It is recommended to use the male bullets when you solder them together, versus removing the male connector and soldering the wire directly into the female connector.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
11.14.2008, 06:37 PM
That's really weird...all of my 6.5mm connectors have a really tight fit. So tight, that I have a hard time pulling them apart lol, but they provide excellent contact. Perhaps Castle need to work on their tolerances a bit.
rchippie
rchippie's Avatar
11.14.2008, 07:49 PM
Bernie at castle & mike at rc-monster said thats sinice im getting full contact & that they are fitting tight , not to worry about it . Just redo my heat shrink to cover the exposed area .
Pdelcast
Pdelcast's Avatar
11.16.2008, 02:27 AM
Probably there was a bit on one of the CNC turning centers that dulled -- and it didn't alarm until sometime after it built a few bad connectors -- and then they were missed by QC (just one thousandth of an inch in tolerance can cause the issue you described...)
I'd suggest you call tech support and just get them to send you an AWR. Tell 'em Patrick sent you.
Patrick del Castillo
President, Principle Engineer
rchippie
rchippie's Avatar
11.16.2008, 11:46 AM
patrick this was acctually my comment . it's all good . I talked to bernie the other day . He said sinice im getting full contact that they are safe to use . but he is sending me another pair just to be sure . thank you for having great customer service. .
