confused about diff fluid
bustitup
confused about diff fluid - 11.16.2008, 01:18 AM
best fluid to use for crt on a clay track....just broke a rear cap joint probably from a jump landing
i'm running a 1515/2.5d on 6s geared 12/62 MMM ......truck wants to pull the front wheels slightely
just use naptha to clean the gears? and dry off with paper towels?
11.16.2008, 09:27 AM
Try 7 20 3
stum
11.16.2008, 10:30 AM
I run 7/30/5 with my 8ight-t on a similar surface
GREYGHOST
01.23.2009, 04:37 AM
If you mix equal amounts of 50k and 10k would you then have 40k?
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
01.23.2009, 11:56 PM
if you want 40k, you need 86% 50k and 14% 10k.
http://www.gesilicones.com/gesilwiza...ng/fluid2.html
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
01.24.2009, 01:20 AM
That's what I said earlier.
BTW: I have that same calculator at my site. I just viewed the formula the script uses and added my own error checking and such. Since it is directly based from that gelsilicones site, I put credits at the top of the page.
Me to
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Me to - 01.24.2009, 01:43 AM
It is best to just buy the correct fluid, as reading the last 2 posts has given me a headache.
You beat me to it James. I was thinking that exact same thing as I started reading their posts. If you have to work that hard to figure something like what portions of each grease to mix in order to get the right concoction for your setup, then it is time to just spend a few dollars and get the right grease in the first place. What a brain twister that is.
Thats what I love about this site though, is having PROs like them to answer a question like that, and then have guys like us who say just buy the right thing up front and avoid frying your brain.
SUPERMAXX YOUR LIFE.
hoovhartid
hoovhartid's Avatar
01.24.2009, 05:36 AM
oops, I missed it the first time. I just scrolled back up and saw it...my bad
cool that you added it to your site tho.
stum
01.23.2009, 07:51 AM
50 + 10 = 60 /2 = 30k So no.. w/o doing the math I'd do about 25% 10k
01.23.2009, 11:20 AM
Equal parts of 50 and 10 gets you 22.5. It's not just getting an average. The formula is:
mixfluidA = ((log(targetvisc) - log(viscfluidB)) / (log(viscfluidA) - log(viscfluidB)) )
mixfluidB = 1 - mixfluidA;
To get a 40k mix, you need 86% of 50k and 14% of 10k.
This should clear things up.
GREYGHOST
This should clear things up. - 01.23.2009, 03:19 PM
Calculating the viscosity of a blended liquid consisting of two or more liquids having different viscosities is a three step procedure. The first step involves calculation of the Viscosity Blending Index (VBI) of each component of the blend using the following equation (known as a Refutas equation):
(1) VBI = 14.534 × ln[ln(v + 0.8)] + 10.975
where v is the viscosity in centistokes and ln is the natural logarithm (Loge).
The second step involves using this blending equation:
(2) VBI-blend = [wA × VBIA] + [wB × VBIB] + ... + [wX × VBIX]
where w is the weight fraction (i.e., % ÷ 100) of each component of the blend. In using the above blending equation, it is necessary that all viscosities are determined at the same temperature, for example, 100 °C.
The third and final step is to determine the viscosity of the blend by using the invert of equation (1):
(3) v = (ee(VBI - 10.975) ÷ 14.534) − 0.8
To sum things up...
To sum things up... - 01.23.2009, 03:54 PM
Considering you have slight tendancy to wheely, you may have about the right fluid in the center diff now, maybe a bit too thick. If the front tires are growing huge the fluid is too thin, and if the truck wheelies then the fluid is too thick. I think some front tire growth is acceptable, as it will help pull the truck around corners. The pro nitro racers run light fluid, and go thru a set of front tires in a single race... I noticed this when looking at the race action pics in the rc mags, and checking out the racer's riders section they usually do on the national race winners.
I run thicker fluid as I like wheelies (no racing for me!) and really like tires to last...
cheesecake
01.23.2009, 09:40 PM
i asked chad bradley this question on neobuggy he said 20-30-1 i ran that the whole time i had my crt and loved it
