CC 2650kv on 6s?
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
CC 2650kv on 6s? - 11.24.2008, 03:38 PM
will it take it?, i plan to run 4s nearly all the time but when i feel the need i have 2 8000mah 3s lipo's here that i may strap it
for speed runs only..bashing i will see striped diffs
  Send a message via MSN to shaunjohnson
bl-is-future
bl-is-future's Avatar
11.24.2008, 03:40 PM
it will handle a few speed runs but i wouldn't push your luck with that high of a kv motor.
shaunjohnson
i pwn nitro
11.24.2008, 03:43 PM
ok thanks, just watch the temps right?
what's the max RPM of these CC neu motors?
shaun
bl-is-future
11.24.2008, 03:55 PM
well the neu's are 60k rpm But the castle may be different. Watch the temps and dont hold it at full throttle for lengthened periods of time. If you constantly run it that high of rpm you cant explode the magnets.
azjc
11.24.2008, 08:21 PM
its not the limit of your motor I would be worried about but the limitations of the mechanics, such as drivelines and gears...if you havnt bought the motor yet I would go with a 2200 kv model....unless you really gear the 2600 kv motor down it WILL run hot due to the higher amperage draw
11.24.2008, 08:59 PM
I've run the 2650 CC on 5s and it had no issues on the GTP or a buggy - 6s doesn't fit my layout well so I havn't tried that yet...
shaunjohnson
i pwn nitro
11.25.2008, 01:09 AM
will the 2650kv be ok on 4s?
i'll usually be running 4s anyway.
and what gearing should i start with?
shaun
Unsullied_Spy
Unsullied_Spy's Avatar
11.25.2008, 01:19 AM
2650: Buggy
2200: Truggy
The 2650 will be fine on 4s, I'd start with a 13T pinion. 6s will be fine as long as you don't hold full throttle for too long. Do NOT free-rev the motor, go downhill at speed, etc. and you will be fine. Considering the voltage drop with the load on the lipos, and the fact you probably won't hit full motor RPMs when used in your Buggy/Truggy you should be fine.
pasan
I <3 RC
pasan's Avatar
11.25.2008, 04:32 AM
Isn't the 2650 offered in the combo? If so will CC have a warning stating not to run it on 6S, a la Mamba Max 7700 style?
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.25.2008, 05:52 AM
Castle has stated you can safely run the 2650 on 6s without harming the motor. The rotors are kevlar wrapped so no harm to the rotor near the 60k limit.
Of course you are looking at speed in excess of 70mph with 6s.
Area 52 Ranch Raceway
T.R.C.R.
shaunjohnson
i pwn nitro
Talking 11.25.2008, 07:58 AM
that's what i wanted to hear
now i just have to make the diffs last
thanks for the help,
u guys here really know your stuff
speedracer1129
11.26.2008, 02:38 PM
Shaun,
As long as you shim everything properly, you will be fine!
