RC-Monster Carbon Fibre
Wow -
12.30.2008, 06:03 PM
Hi guys!
just ran my car in the park for the first time and i am amazed its pretty fast but has so much torque! and the runtime is fantastic
heres my setup:
e-revo
MMM combo
22/65 gearing
2x 3s 5000mah neuenergy lipos
here are some pics of my car:
but i have soo many questions! i actually cant believe how many ive managed to rack up this time!
i dont expect answers to all of them! i just need a place to write them down permantly somewhere so i can refer back to them some of the arnt even questions, mearly statements of surprise lol
ok here i go:
(in no particular order)
1. I cant seem to fit the gear cover onto the top of the gears where it should go (i have the single motor mount). i can get it on, but it is really hard to, and once its on the spur gear keeps rubbing against it. is this part really necessary, or is it safe to run without out?
2. this really surprised me: i have two 3s 5000mah neuenergy lipos lasting 40 minutes with still 3.81-3.82v per cell in them! I charged them up fully before i went out, but once i was out it was proper hard running, speed runs and everything! and these lipos lasted for at LEAST 40 minutes. i say at least, because after 40 minutes it got dark and i had to go home. I hook the lipos up to the charger and each cell has around 3.8v still left in them!! not even close to the 3.2v LVC that i had set. This really amazes me.
3. brianG's speed calculator says i should be going at least 50mph, but it seemed like it was going 40-45mph. no matter, still pretty fast!
4. I just have velcro holding down my MMM, and i did some pretty wild sumersaults and its held on fine, no need for zip ties!
5. during and after my running session, i constantly felt the MMM, motor and lipos. during the entire session, the MMM and lipos were cold, and the motor was barely warm, even with continuous speed runs. amazing! i dont understand how people are getting such high temperatures.
6. should there always be a spark when connecting lipos, cos there isnt anymore, but there used to be when i connected them a couple of days ago.
7. how does the MMM let you know when the LVC is kicking in?
8. as the lipos are used in a session, does performance decrease steadily, or is it a sudden drop in performance once they reach a certain point?
9. the next time i drive, i will run the lipos down to the LVC of 3.2v per cell. after i done this, when i get home, should i charge them up to 3.7v per cell? or should i just fully charge them to use next time? or should i just leave them as they are until next time? is there a way i can program my hyperion charger to just charge them up to 3.7v per cell?
phew done!
Dsm needed
12.30.2008, 06:25 PM
3. brianG's speed calculator says i should be going at least 50mph, but it seemed like it was going 40-45mph. no matter, still pretty fast! Wind factor is a big help here, you might be "doing" 50mph, but the wind is holding it back.
4. I just have velcro holding down my MMM, and i did some pretty wild sumersaults and its held on fine, no need for zip ties! Nice, some people have luck, some don;t
5. during and after my running session, i constantly felt the MMM, motor and lipos. during the entire session, the MMM and lipos were cold, and the motor was barely warm, even with continuous speed runs. amazing! i dont understand how people are getting such high temperatures. AWESOME
7. how does the MMM let you know when the LVC is kicking in? I think the MMM starts to studder and go on and off, i could be wrong
phew done!
I tried to answer what i knew, I don't know much, LOL
Brushless only!
12.30.2008, 06:27 PM
1: try a heat gun on the cover and push it out a little. mine rubbed a little too. Heated it up and noe its good.
2: great to hear that you runtimes are that good!!!
3: His calc gives a great estimate. Its been really close on every thing but the lst.
4: just be careful b/c the case can open up on you
5: geared correctly the castle motor runs really cool on 6s. Looks though you found the sweet spot!
6:The spark is from the power capacitors chargeing. Its normal and ok
7:it slows the truck down alot.
8: you wont notice any decrease in you power using a good lipo until they are dead! they dump quick. If your battery lasts 40 mins max you will have near the same power at 1 min into it as the 39th min.
9: only charging to 50%(store mode) is only if you are not going to play in the next two week. If you are going to play again in the next two weeks fill the battery up!
HOPE THIS HELPS!
12.30.2008, 06:28 PM
1. Might not fit with some pinion & spur combos due to the large diameter of the gears- I wouldnt worry, 99% of us dont use gear covers and I've only seen one case of a stone getting caught and killing the esc as a result.
2. Lipos = win  Bear in mind resting voltage will be higher/rebound a little than when you are running the truck.
3. I doubt your eyes can tell the difference between 45 and 50mph  I always thought my hvmaxx setup was pushing my gmaxx along at ~35mph, but in reality it was only ~20mph, once I did the sums on the calculator. You need a GPS or radar gun to get an accurate idea.
4. Good for you, but make sure the velcro doesnt come unstuck from the chassis (I would get the optional holddown when its released).
5. We're in the UK dude, its like 2*C outside! I would get a proper IR temp gun though for accurate readings, but your findings so far are excellent.
6. The caps on the esc will hold a charge for quite a while, so they wont recharge every single time you connect the lipos, which is nice (sparks make me nervous, reason why I didnt want to learn how to weld at school...).
7. Truck stops moving. Sometimes it may become jittery on the throttle, or so people say, but usually the truck will simply grind to a halt. You will see it slowing down as the lipos begin to dump though, so you will usually stop running the truck before the lvc kicks in.
8. See above. the discharge curve of lipos is very flat until the last 30 seconds or so.
9. Depends. If you plan to use the truck again in the next few days or so, then charge them up fully. If you dont plan to run it for a week or more, then a 'storage charge' of ~3.7 volts or so is recommended. You should have that feature on your hyperion, if not you can simply stop the charge once the voltage of each cell is roughly 3.7v also- you should be able to see the individual cell voltages if you press the right button during charging, see your manual.
Fun fun fun...
RC-Monster Square Tube
12.30.2008, 06:36 PM
I can only help you with #9, from my Hyperion Duo manual-
ALWAYS store your packs at 60% of capacity. After a day of flying (uhhh... driving) use Store Mode to acheive this.
It is especially harmful to store lithium packs fully charged, and should be avoided for a day or two at most.
..... There ya have it, right from Hyperion.
12.30.2008, 06:39 PM
The other guys answered your questions pretty well, but I want to interject my $0.02 about #6. There should always be a spark when hooking up the your last connection because the caps are always discharged when you remove the battery.
Depending on which ESC you got: a "true" V3 with wires directly soldered to the PCB, or an V2 upgraded to V3 with connectors on the PCB instead.
What might be happening is that the first couple/few times you plugged the packs in, you ablated the heatsink on the MMM. The heatsink is VERY close to the power plugs, sometimes even touching. When you plug the batteries in, the heatsink shorts out the pack for an instant and basically vaporizes the itty bitty contact area between the heatsink and connectors. After a while, all the aluminum is ablated away and you no longer see a large spark.
Or, your battery connectors could have gotten pitted from the sparking during the first few connections.
Or, you just got better at smoothly hooking up your battery connections, which helps reduce the spark.
12.31.2008, 08:21 AM
wow thanks for all these replies guys, its great! i also posted this on the traxxas forum and got 1 reply!
the outside temp when i was running was about 5 degrees C maybe? not sure...
about the batteries, i thought 8000mah was meant to last you 45 minutes, and 5000mah about 20-30 minutes. that was the downside of running 6s in the e-revo. i cant understand how my runtimes are that good. im gonna take it out today to see if it was a fluke!
I got the MMM combo, but the MMM has bullets all round, including the battery side. both bullets are touching the heatsink, and i am afraid of breaking them if i try to pry them away. does this mean they are shorting out my lipos? i remember hearing that CC insisted it wasnt a problem
12.30.2008, 06:48 PM
Interesting...
With my V1, there is no heat sink rubbing issue, but Im always nervy about connecting up my lipos every time so my technique isnt smooth at all, so in theory there should be a spark every time for me too; but there isnt.
Would the caps always discharge every time you unplug the batts, or is it dependant on if you turn the esc off first (which I do), and also the location of the caps on the circuit- are they in parallel to any components that would drain them regardless of the esc being on/off or hooked up to batteries etc?..
12.30.2008, 08:08 PM
Originally Posted by suicideneil
Interesting... so my technique isnt smooth at all
Practice makes perfect to make a smooth entry...
JERRY2KONE SUPERMAXX
Questions. -
12.30.2008, 08:19 PM
Hye there. It sounds like you have answers to most of your questions for the most part. Nice setup and congradulations on your success with the operation of your build. One added note on teh gear cover on your tranny. I used longer screws and placed nylock nuts on the screws first, which makes a small gap between the cover and the mounting plate. That took care of the rubbing issues for me, protects the gears from grabing any wires, and also gives you a little cooling effect for the gears during heavy useage. It works great and it is easy to install and remove just like normal. Good luck with continued success with your project.
12.30.2008, 08:48 PM
My girls like it rough...
12.30.2008, 08:59 PM
You mean the one you inflate?
12.30.2008, 09:36 PM
No he is talking about Palmela Handerson...
And the bicycle pump does all of the work...
12.30.2008, 06:54 PM
The caps are hooked directly to the power leads. It has been confirmed that even with the power switch off, there is still current flow that can deep discharge your batteries. If it can discharge batteries over several hours, it can certainly discharge the caps over a few minutes. I guess there could be some residual charge on the caps. Maybe that once the cap voltage gets below a certain value (~5v), the current drain is minute. Then, that would mean there is SOME voltage on them and then won't spark as bad next time...
12.30.2008, 08:22 PM
Not to high jack the thread!.. (I'm sorry guys)
Jerry!! I wanted to put you builds in the (Best of the BEST 08) but I couldn’t find the thread. a little help please..
Thanks and sorry again..
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
