12.30.2008, 06:48 PM
Interesting...
With my V1, there is no heat sink rubbing issue, but Im always nervy about connecting up my lipos every time so my technique isnt smooth at all, so in theory there should be a spark every time for me too; but there isnt.
Would the caps always discharge every time you unplug the batts, or is it dependant on if you turn the esc off first (which I do), and also the location of the caps on the circuit- are they in parallel to any components that would drain them regardless of the esc being on/off or hooked up to batteries etc?..
