My Losi 8T Tekno Conv.-Modified for low CG
himalaya
himalaya's Avatar
My Losi 8T Tekno Conv.-Modified for low CG - 01.07.2009, 04:50 AM
Hi all,
I just finish my second bashing on my newly built Tekno Losi 8ight-T, I love it so much and think I should share some with you.
The idea is to achive lowest possible CG. Major modification is the Lipos' layout. Two 6S 25C 2.6Ah LiPo packs are layed in line at left side, right above the chassis, no tall battery in a small tray. To do this I customized a fiberglass epoxy board to make a long battery deck.
Radio box, mechanical brakes and clutch are left unused.
Tekno's design put the ESC on left-front side, results in unacceptablly long motor wires.
I moved my MMM to the right, it was inserted between the motor and receiver, just a perfect fit, like it was originally designed that way. (it's where brake servo locates in Tekno's design)
The Two 6S 2.6Ah battery was connected in parallel to get a 5.2Ah capacity, while lowering current stress on each wire by 1/2 and heat generated to 1/4.
Does the CG look low?
"CVD condom"
fiberglass epoxy battery deck
....What a Blue Sky....
himalaya
himalaya's Avatar
01.07.2009, 04:55 AM
Now I have switched to this motor.
I was impressed by the bearing size.
01.07.2009, 10:05 AM
Very nice!
Very Nice
js058515
Thank You Brushless Gods!
js058515's Avatar
Very Nice - 01.08.2009, 02:18 AM
Great job on the the mods....and thank you for posting very nice photos that show the detail of your handy work. Be sure to protect your batteries!
BL Dreamer
01.08.2009, 04:38 AM
What did you do to achieve the nice low stance...looks sweet. How do you run 12s on a MMM 2200?? Very cool rig.
bensf
01.08.2009, 04:45 AM
He is running them in parallel.
BL Dreamer
01.08.2009, 05:47 AM
Okay...Im learning so bear with me. If in parallel it makes it a 6s and it will have just twice the capacity not actually make it 12s??
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
01.08.2009, 06:11 AM
Yup- so if he has two 2600mAh parallel, then he has 5200mAh 6s.
If he ran in a series he would have 12s 2600mAh.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
BL Dreamer
01.08.2009, 06:13 AM
Thanks hoov...Im getting it now.
jayjay283
jayjay283's Avatar
01.09.2009, 06:37 AM
man I swear, just climb out of it, I have no issue. Just be all that you can be
himalaya
himalaya's Avatar
01.09.2009, 01:02 AM
Yes I run the two batteries in parallel to get a 6S 5.2Ah 25C LiPo. This config killed my first MMM V2, my seconde V2 survived after updated to firmware V1.2.
Major problem of my mod is a difficulty to change the batteries. To securely fasten the LiPos I use a combination of Velcro and bolts, when change batteries I have to unscrew the six nylon lock nuts, not as convinient as original velcro-only setup, but is obviously much tougher. The good side is, the 22.2V*5.2Ah=115Wh energy lasts at least half hour, so not that often does the LiPo need to be changed.
George16
Supermaxx
George16's Avatar
01.09.2009, 01:08 AM
Can't you use a thicker material for the bottom part so you can cut channels for the straps to go through? This way, you can remove the clamps.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
himalaya
himalaya's Avatar
01.09.2009, 01:30 AM
Yes, this is a great idea. Actually the straps are going underneath the epoxy deck, the CNC machined grooves on the Tekno chassis provide channels for the straps.
Problem here is my deck has no side walls, without strong hold down force the batteries will slip back and forth during running and jumping, hit the steering post etc. Maybe I need Mike to make me a custom CNC machined battery tray.
BL Dreamer
01.09.2009, 03:37 AM
I think a aluminum machined tray would be alot of weight to an already pretty heavy side of the buggy wouldnt you say? Maybe some kind of lighter composite would be better suited.
Ryu James
Ryu James's Avatar
01.09.2009, 07:56 AM
you should totally have Mike make you a battery tray. i saw in another thread that he said he can literally make any size tray you want. he is only limited on it being 1" high sidewalls. but as far as length and width there are no limits. you could have a tray that runs the whole length of your chassis and fits both batteries. also it would be grooved for your velcro straps. it would look much nicer and work better and probably only cost you about $50. just put in your dimensions on the site where you can order custom size trays.
http://www.rc-monster.com/proddetail...erytray&cat=18
Jammin SCRT10 Neu 1512 1y
