Torque twist
rchippie
rchippie's Avatar
Torque twist - 02.22.2009, 09:58 PM
I noticed i have a little torque twist on my crawler . Under power the LR wheel compress & the RF lifts . So i put thicker oil 60w in the LR & added more preload . It still has a little . There is no added weight in the FR wheels yet . It has duratrax 3 1/5 inch aluminum shocks . this is how my truck is set up now . Did i put the thicker oil in the right shock ?.
http://skellyo.com/fs/DMGCrawler/DMGCrawler3.JPG
REAL MEN RUN BRUSHLESS
TexasSP
Something, anything, nothing
TexasSP's Avatar
02.22.2009, 11:05 PM
I believe that converting the upper 3 link to 4 link will help as well. The Crawler Store among others sells the conversion pieces.
www.cubicle101.com
rchippie
rchippie's Avatar
02.23.2009, 07:12 PM
I all ready have that part on my truck . Im just trying to get rid of the little bit thaqts left .
02.23.2009, 07:48 PM
Shafties will always have some torque twist...
If you have not added weight to the front wheels yet it will make a huge difference in crawling ability. It will not help torque twist though. Usually some added preload on the right (not sure of the side, but it would be the side that compresses while going forwards) rear spring will help with torque twist. Some link setups do twist more than others though, my j-keeper does not really twist, even with the big outrunner...
rchippie
rchippie's Avatar
02.23.2009, 08:45 PM
Thats what i hear james . It's my LR that compresses under power & the RF lifts under power . I put thicker oil & added preload to the left RR . That helped but i would like to get it a little better . so i have to order stiffer springs from tower .
Andrew32
02.24.2009, 12:03 PM
i have 4 links front and rear
70wt oil on LR and a bit of preload.
im getting a good 61 degrees with it. There will always be Twist tho. Just gotta learn to drive with it
skellyo
skellyo's Avatar
02.22.2009, 11:07 PM
Read the text in this item description...it tells you how to mount the rear links like I was telling you about.
http://www.tcscrawlers.com/On-Sale-4...g-p-16612.html
rchippie
rchippie's Avatar
02.22.2009, 11:17 PM
I all ready read that . I wanted to try the shock first . Mounting the links like that wont hurt the crawling ability of the truck ?.
skellyo
skellyo's Avatar
02.22.2009, 11:38 PM
No, shouldn't make any difference with the ability of the truck.
George16
Supermaxx
George16's Avatar
02.23.2009, 06:10 AM
I just made my own 4 link using a piece of 5mm lexan for my son's AX 10. Works well, and didn't affect the crawling ability of the truck at all.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
George16
Supermaxx
George16's Avatar
02.24.2009, 06:18 PM
ANdrew32, what shocks are you suing on your setup?
Revo with OS .18TZ
Andrew32
02.24.2009, 07:22 PM
stock with a 1/2" spacer on the inside and 1/4" spacer on the outside.
Running Badland tires. Ill see if i cant get some footage today at the LHS
rchippie
rchippie's Avatar
02.26.2009, 10:57 PM
How much preload to use on your crawler shocks ?.
johnrobholmes
johnrobholmes's Avatar
02.27.2009, 01:23 AM
I use enough preload to keep the springs loaded when fully drooped. I also add internal springs to make the rig 50/50 droop/sprung. With the way that crawler is set up, you could stand up the rear shocks more too.
To try and combat the torque twist, you could bring your lower links in closer to center at the chassis side. You need to bring the roll center down a bit.
Your shocks are too short to have a 50/50 setup though, it is set up best for full compression.
---JRH---
rchippie
rchippie's Avatar
02.27.2009, 02:15 AM
Thank you john. I stood the shocks as far i could. They are now at about the 12:05 postion . If your looking at the old pic . That is 2 holes back .
What do you think about using hi clearence links on the FR ?.My crawler has the tcs 4 link convestion plates on the FR & RR the rear. Im running the asemetrical setup to help with the torque twist on the RR . How should i mount the FR upper links to the TCS plate, on the top or bottom or does it not matter ?.
