40 series rim question
40 series rim question - 02.24.2009, 12:14 AM
So I plan to run some 40 series moabs on the flm savvy.
The comando beadlocks I have seem to have about a half offset, the hex is about centered in the width of the rim. I would prefer a bit less (more?) offset for a wider track. I am not worried if I have to use non beadlock wheels, just want a different wheel. I would also like a spoke or chrome wheel, dish wheels are a bit boring...
Also can do 17 or 23mm hex wheels.
02.24.2009, 12:16 AM
Do you need any 40 series moabs? I have a BN pair
02.24.2009, 12:19 AM
How about these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEC1&P=7
No info about offset though...
These list a 20mm of set, but it looks like that is from the front, not the rear???
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEE1&P=7
Finnster
KillaHurtz
Finnster's Avatar
02.24.2009, 09:34 AM
How about these?
The first ones are what I plan to run when I go to replace the Terrapins on my Savage now w/ 40s. If you want 17mm hex on 40 rims the choices are really limited. I think they are a std 1/2" offset.
If you want more offset, you could always try using the XL axles which have ~+12mm of width per side. If you have a std Sav X, you would have to upgrade to the Super HD diff output cup and XL/Flux axles tho. Also, if you have the hex hub conversion set, Ofna extended hex hubs for the Hyper series could work possibly. They offer upto +12mm as well.
squeeforever
squeeforever's Avatar
02.24.2009, 12:37 AM
I personally like the Cheyennes, but they might have a bit to much offset. Not sure. Why not the Cheyenne narrow beadlocks? They were designed for the Moab XLs...
02.24.2009, 12:40 AM
Pmed
The narrow beadlocks will not work very well with the moab 40s, as they are quite wide. The moab xls are much taller and narrower.
Too much offset on the cheyennes in what direction? I want the track to be wider than the commandos can offer...
squeeforever
02.24.2009, 12:46 AM
Pmed
Ah...I gotcha. You want more offset then, not less. Then the Cheyennes might be enough for you, of course they have the usual 1/2" as do most 40 series, including the Commandos. It looks like it has less offset on the Commandos for some reason, but its the same as a offset Velocity or the Cheyennes. 1/2" offset is quite a bit.
Erevocanuck
02.24.2009, 02:35 AM
I used Axial Over sized beadlocks on my E-revo & on the front the inner beadlock ring rubbed on the front suspension.
jayjay283
jayjay283's Avatar
02.24.2009, 08:52 AM
the axials do tend to rub IF, you use the 14-17mmmm plasitic hex adapter, and not 17mm hex hubs, the 2mm the hex hubs move out the wheel is just enough so they dont rub on my emaxx or muggy... Great wheels
Proline used to make those wabash wheels in like a 3/4" offset but I dont see them anymore
make mike whip up some more of these, LINK looks like a sick offset !
TexasSP
Something, anything, nothing
TexasSP's Avatar
02.24.2009, 10:48 AM
I like my commandos but those Axial's look dang good.
I was lucky and scored some lightly used 40 series Dirthawgs mounted on Commandos with the 23mm adapters for 70 shipped. I see guys popping these up on rccrawler.com all the time. In fact that is one of the best places I have found to get used tires and wheels.
www.cubicle101.com
