Flux slipper clutch adjust ?
samintrepid
samintrepid's Avatar
Flux slipper clutch adjust ? - 02.28.2009, 02:30 PM
I have burned slipper pad because from factory it too loose and hpi recommand "Tighten set screw fully then loosen one half turn" after rebuildind I loosen 1/8 turn and all working good no more slipping clucth and wheelie all time and now did we think is better to loose slipper at minimun 1/4 turn for protect the drivetrain or 1/8 it ok ?
Thank !
Revo_Troop
Military Muscle
Revo_Troop's Avatar
03.01.2009, 06:48 AM
sounds like you got it right where it needs to be..for my BL ERevo I had teh same setting till I wore it out even more then it was tightened all the way till I finaly finished it off..I got a rebuild kit on order..you may want to have some spare slipper clutchs cause it sounds as though you may need some too with that BL power
  Send a message via Yahoo to Revo_Troop
