Medusa tapeing
Jeremy1976
Medusa tapeing - 03.18.2009, 01:53 PM
Should you tape both ends and cover the holes or just the wired end? Thanks
Fast5sRevo88
03.18.2009, 02:02 PM
Well the holes are bigger and are more numerous on the back, therefore the back is the only part i taped up (used decals so it would look cooler). I left the front holes un-taped for a little airflow, but i also use mike's heatsink which mostly covers the holes up anyway.
GO-RIDE.com
03.18.2009, 02:05 PM
I taped both ends of my Medusa motors. If dirt or a small stone get in you could ruin your motor and fry your esc pretty quickly.
E-8ight - Tekin RX8 2000kv/4S
Jeremy1976
03.18.2009, 02:13 PM
Both ends it is then. I am only going to be running on the black top but would rather be safe than sorry. I am waiting on mike to finish up the end covers! Thanks guys.
OZ-RUSTLER
OZ-RUSTLER's Avatar
03.18.2009, 06:52 PM
Anyone try this (cell pic)
[IMG][/IMG]
Just a VXL endbell cover. Mine is just wedged there alongside the front chassis brace. It doesnt clip on like the VXL motor because of lack of screws, but I think with some small amounts of thermal paste it will be fine. On the front I just have a piece of thin lexan cut to size.
kvrc
03.18.2009, 07:32 PM
when i talked to jeff from medusa he said to go ahead and tape up all the holes if you feel you will be getting any dirt in the motor. the motor dosent actually flow any air internally anyways.
BitHed
03.18.2009, 10:43 PM
...well thats a surprise...Thanks for that info...
...so in theory all the cooling we should be thinking about is EXTERNAL? ie Heatsinks with big prongs? I prefer prongs to splines :D
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.18.2009, 10:52 PM
I have put hv heatsink on my 70-2300 medusa motor and do great job
http://www3.towerhobbies.com/cgi-bin...?&I=LXNAB1&P=7
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.18.2009, 09:34 PM
I've never seen the vxl solution before... Can you buy the end cover by itself?
OZ-RUSTLER
OZ-RUSTLER's Avatar
03.18.2009, 10:10 PM
Here you go
http://www3.towerhobbies.com/cgi-bin...?&I=LXSGY4&P=7
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.18.2009, 10:48 PM
I like this v-cover i will get one and remove my alm tape from my medusa thanks for this great job
BitHed
03.18.2009, 11:05 PM
...yeah i have sinks on them but i am just surprised that Medusa says 'yeah go ahead and close up the holes'...
DARKWAV
03.19.2009, 02:13 PM
Hey Bit...If you look at Medusa's website they mention that one of the specs provided assumes airflow.
"*Based on adequate air flow around motor, i.e., open air stream behind propeller"
So that caveat seems to be there to indicate that to some degree either performance or some operating limits can only be achieved under certain optimal conditions.
I think it is cool that the recognize the surface market and the conditions we put our r/c's through. As long as my temps stay within reason, I'm sure my motor will last longer if I take measures to prevent dust and debris from entering the can
Jeremy1976
03.19.2009, 02:29 PM
My Medusa was cool as ice yesterday and all I was doing is major wheel spin and it was wide open within a second of my pulling the trigger. My buddy Brian's VXL was quite a bit warmer. Same battery packs exactly we were running and similar gearing.
MetalMan
MetalMan's Avatar
03.19.2009, 01:21 AM
The Medusa has no way of pushing air through itself. Ideally if it were in a plane air would flow through it due to the propeller. So even with the ends open in a car/truck, the amount of cooling due to the holes would be minimal when not covered up.
