Who could rewind my outrunner?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
Who could rewind my outrunner? - 04.05.2009, 09:08 PM
I am working on my e-bike project. I picked up a 100a suppo esc from hobbycity along with a 250kv outrunner. It is wayyyy overgeared. Could somebody rewind it to a lower kv? About how much would this cost?
I don't know what kv I need either. I'll need to calculate the gearing. What does it take to figure out how chains and sprockets effect gearing? Is it just like a spur/pinion?
and since pics always help -
edit - tell me if the pics don't work. Might have messed them up.
sabongi
04.05.2009, 09:44 PM
try using a faaar smaller pinion...
Metallover
Metallover's Avatar
04.05.2009, 09:48 PM
I can't get too much smaller...
johnrobholmes
johnrobholmes's Avatar
04.05.2009, 10:03 PM
What is your total geardown on that sucker?
What is your voltage
What speed do you want to hit?
geardown is just like an RC. Find the ratio between pinion/ spur, and then multiply by the ratio on the second and third reduction.
---JRH---
sabongi
04.05.2009, 10:06 PM
Have you tried using a big spur on the upper right side of the bike?
johnrobholmes
04.05.2009, 10:05 PM
I see now you are using a stoker setup. Can you run the chain from your stoke hub to the biggest ring on your cranks?
---JRH---
Metallover
Metallover's Avatar
04.05.2009, 10:25 PM
I could do that but I'd have to get a couple chain links and the pedals would spin really fast. I might do that if rewinding it proves impractical for the cost.
sabongi - That part is a freewheel and acts as a pinion. Making it bigger would make the gearing even worse.
The gear reductions are - 11/72 to the "spool", 14/32 to the crank, and 48/12 to the wheel in top gear. I want to get about 35 in top gear. The motor is 250kv at the moment and I'm running 24v. That's 6000rpm. The wheel has a 13" radius so 2pi13=81.7 inches/revolution.
I'm not quite sure on my math, but I think I get 1,584 rpm at the wheel so that's... holy sh!t - 180mph!! - Someone check my math...
I figure I will need 1,168rpm at the motor so thats... 49kv.
Is this going to work out or will I need to make some major changes to the gearing?
whitrzac
Can't catch this...
whitrzac's Avatar
04.05.2009, 11:01 PM
I think your best bet would be to get a 3s lipo
IDK if a flux capacitor will fit on a bike though
crazyjr
crazyjr's Avatar
04.05.2009, 11:34 PM
it's been a while since i was in school, but i thought it was pi X diameter, not 2pi X diameter. if you do single diameter you get 40.82. Still moot point because if everything else is right, you are still looking at 90 mph and still need further reduction or lower kv
Bad Karma
04.05.2009, 11:39 PM
metallover's right... It's 2*pi*r to get circumference or a circle
crazyjr
crazyjr's Avatar
04.06.2009, 02:05 AM
My bad, didn't see the radius, I assumed diameter
Metallover
Metallover's Avatar
04.05.2009, 11:18 PM
I think another 5/1 gear reduction will do the trick. Ill see if I can figure out a way to do that tomorrow.
Snipin_Willy
Snipin_Willy's Avatar
04.05.2009, 11:43 PM
nice project, but you think you could have chosen something other than a lead weight to put a motor on? Those Mongoose bikes are HEAVY!
Maybe make it a downhill battery charging bike?
Metallover
Metallover's Avatar
04.06.2009, 08:02 AM
It is a heavy bike... Its really heavy with the new stuff too! I think it was 35 before the stuff and now it's probably 65+ pounds.
To all those who checked my math, it seems I did it right? I sure hope I did. I'll figure out a good way to do the rest of the reduction at school today. Nothin better to do....
johnrobholmes
04.06.2009, 10:17 AM
You won't be able to do a single stage reduction with that motor.
A 14/72 into 14/36 would be about as close as you can get to ideal, although a larger than 36t rear sprocket would be better. The only hitch with using the top hat adapter is that you will need a left side drive freewheel.
---JRH---
