BKWanderer XL against Feigao XL
Nick
COOKIES!
Nick's Avatar
BKWanderer XL against Feigao XL - 01.20.2006, 07:24 PM
I did abit of research today into the BK xl motors and Feigao xl motors.
Alot of people said they are the same and so on but found that the KV rating was different by around 200-300kv a volt.
Taking the 7xl as an example:
Wanderer = 2145kv
Feigao = 2382kv
So the Feigao appears to be the better motor but again wondering how much difference it would make, I did an example on 16 cells: (assuming all the cells were of top 1.2v).
2145 x 19.2 = 41184
2382 x 19.2 = 45734
So it has a large difference, I'm guessing nearly a whole cell power difference? Not sure how KV ratings worked and I hoped those calculations are correct.
Why have RCM stopped Feigao XL motors?
Anyway, I hope my research is correct, was intresting to read about, hope someone can tell me abit more about KV ratings, thanks. :)
~ Nick.
Superemaxx89
01.20.2006, 07:28 PM
it had something to do w/feigao's quality of bearings or somthin
Nick
COOKIES!
Nick's Avatar
01.20.2006, 07:31 PM
It was said the Wanderer has better bearings that do upto 100kRPM?
But if they place better bearings in, why lower the KV.
~ Nick.
Gustav
Gustav's Avatar
01.20.2006, 07:33 PM
The Feigao's kv is not measured under load and the wanderers are.That's the reason for the Kv difference.They are the same other than the bearings and the colour.
Also the wanderers have the female 5.5mm plugs already soldered on.
coolhandcountry
coolhandcountry's Avatar
01.20.2006, 07:36 PM
Yep gustav has it. The load difference of the motors. So you have to figure that into the feigaos.
Nick
COOKIES!
Nick's Avatar
01.20.2006, 07:38 PM
Can you define the "load" for me?
~ Nick.
squeeforever
squeeforever's Avatar
01.20.2006, 07:41 PM
the "load" would be exactly that, with a load. such as, in the truck would be with a load or out of the truck would be no load.
Gustav
Gustav's Avatar
01.20.2006, 07:42 PM
eer,yeah ,that the motor has a resistive mechanical force acting against like when it is in the vehicle.Like how a higher gearing or a heavier vehicle is a higher load.
Gustav
Gustav's Avatar
01.20.2006, 07:45 PM
Also brushless motors don't like running unloaded,so they get hot when your gearing is too low.That's why i think it is possible to have a too big motor for a certain vehicle,not enough load to keep it cool/efficient/happy.
Dafni
Dafni's Avatar
01.21.2006, 02:38 PM
I was told at BK they test the motors with a big propeller as load.
