FLM half case and G1 single speed.
RC Fan 4 Life
FLM half case and G1 single speed. - 02.05.2006, 12:01 AM
for thouse of you who have this does using only 4 screws hold the trans in good? Did you only use 4 screws to hold down the chassis braces?
Do you need to put any grease in the trans?
squeeforever
squeeforever's Avatar
02.05.2006, 04:42 AM
i think a little grease wont hurt. as for sturdiness i think it should be just fine.
nitrostarter
nitrostarter's Avatar
02.05.2006, 12:44 PM
It should be very sturdy, 4 screws into a CNC'd aluminum case instead of a plastic case. The aluminum wont give or strip out like the plastic might.
N. Rustler conversion
squeeforever
02.05.2006, 01:03 PM
just remember to use thread locker.
RC Fan 4 Life
02.09.2006, 11:16 AM
Do you need to put any grease in the trans? If so what kind that i can get from a auto store.
squeeforever
02.09.2006, 08:40 PM
no grease. i would just put a very little on the gears if you run a steel idler. you wont need much at all. i just use associated black grease.
Serum
Serum's Avatar
02.10.2006, 06:43 AM
I use dry lube in the transmission.. grease won't stay put.. at 7000 rpm, it wil fly off..
