The ISC Ultimate Speed Run 2009
Nic Case
Fast RC-Monster
Nic Case's Avatar
The ISC Ultimate Speed Run 2009 - 07.31.2009, 09:43 AM
Sign-up time for the Ultimate Speed Run is here!
***How Fast is you R/C Car or Truck? ***
Come find out, with a dual optical speed trap & optimized conditions.
It will be held at the Auto Club Dragway Nov 14th & 15th. 2009
Entries will be limited to 60 - so acting quickly is advised.
The Biggest– most highly publicized Radio Controlled Speed Run ever!
Compete for Top Speed World Records – in the 12 separate ISC classes.
This Straight-Line Event will be 2 days of exciting action.
Bring It!
N
http://www.rc-isc.com/
07.31.2009, 09:57 AM
Can we send you a car to run?
Nic Case
Fast RC-Monster
Nic Case's Avatar
07.31.2009, 10:08 AM
I'm flattered.
What do you have? What's in it?
But if you have a car or truck to send (and you cant get there yourself)
I'm sure we can find a qualified individual to run it....LOL
I forgot to mention -- anyone that makes a pass over 100 mph will receive a 100 mph club hat !
Cheers
N
nitrostarter
nitrostarter's Avatar
07.31.2009, 10:18 AM
Well I'm planning over 150mph, do I get a special hat too?
Glad to see you here Nic, and good luck at the event. Lets see some outrageous numbers again!
N. Rustler conversion
hoober
08.01.2009, 11:10 AM
If you make 150 , you get 1.5 hats.
Electric stock (2wd and 4wd) rule is pretty clear (I think) with a single 2S pack , but for electric mod can the pack be made with 4S of 2P cells?
The voltage max seems clear that it is intended to guard against overcharge, but there is a rule that is stating max of "4 cells" , my proposed set-up is technically 8 cells.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.31.2009, 10:42 AM
Man you guys are lucky down there... I wish we had something like that in Canada.... California is so far away... darn it..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.01.2009, 12:06 PM
^^^ I guess you'll have to run in the "Electric Open" class. IMO putting two packs in series OR parallel makes them 1 pack. So putting two 4s packs in series (although separate packs) would count as an 8s pack.
hoober
08.01.2009, 12:28 PM
That's not quite what I meant. Here's:
2 small 2200 mah cells soldered permanently together in parallel to make one 4400 cell.
Make a 4S pack out of these 2P 4400 cells, technically there are 8 cell , but still falls within the max votage and max series rule. Really no difference in performance than a pair of 4S packs in parallel.
What's_nitro?
08.01.2009, 12:34 PM
Oh, you meant 8 cells as in the "number of cells in the car". Not necessarily "the number of cells in the battery" (?). Should be fine then.
Nic Case
Fast RC-Monster
Nic Case's Avatar
08.07.2009, 11:11 PM
Whatcha got?
Nitrostarter
thanks for the warm welcome
– wow 150 --that’s the spirit!
If you (or anyone) needs some help, I'll do what I can to pointcha in the right direction
Aqwut
Yes we are a bit lucky (California is the place you otta be...)
Hoober & What’s Nitro
You guys got the intent right – just bring it out and go fast!
There's a class for just about every car made..
Check out the sign-up list ---> http://www.rc-isc.com/forums/showthread.php?t=266
N
08.07.2009, 11:16 PM
Nic - I was contemplating something but actually going v slow now and going to the world rock crawling champs instead lol...
Not sure I can so slow and fast this year - I'll see when I get back but was thinking about a super mod CRT.5...
I'll see if mikes interested in helping...
What's_nitro?
08.08.2009, 10:35 PM
I see there isn't a class for non wheel-driven vehicles....
Nic Case
Fast RC-Monster
Nic Case's Avatar
08.21.2009, 10:19 AM
Things are heating up......
http://rc-isc.com/forums/showthread.php?t=266
How fast do you think you can go?
N
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.21.2009, 11:52 AM
Anxious to see you beat your record Nic, Good Luck !
Nic Case
Fast RC-Monster
Nic Case's Avatar
08.21.2009, 12:22 PM
Thanks!
I'm not even sure if I can break it.......
Conditions have to be juust right.
N
