flip flop switch
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
flip flop switch - 09.19.2009, 07:32 AM
i know it'd take castle a little adding to put one into their ESC's...but i cant possibly think of a better addition to ESC's like the MMM!!
i'm sure there is a V4 in the works. can we please have a flip-flop-power-on switch installed to ESC's?
reason being is i belive that the current MMM switches are turning off because of G-force acting on the switch and turning it off..totally convinced!
a flip-flop switch for thoes who dont know is a small device that turns a momentary switch into a on/off switch.
hence you can use a micro-switch like the one used for buttons in your car sterio to act as an on/off switch.
these switches are very light and i highly doubt they will be affected by the massive G-forces the cars are put under so they wont turn off!!!
i would do it myself but i cant get 6v from the switch wires on the MMM and getting 6v from the reciver is pointless untill the unit is turned on....which you need the switch to do.
but with castle's shop i'm sure a flip flop switch intergration into the MMM's low voltage brain board cant be too hard!
hope one of the crew hears the plea for help
shaun
  Send a message via MSN to shaunjohnson
brushlessboy16
brushlessboy16's Avatar
09.19.2009, 07:41 AM
I say a momentary push button to arm the esc :)
or beter yet. Make open circuit on so that if a switch were to fail we wouldnt be scrambling wondering why our Esc's dont work. :)
shaunjohnson
i pwn nitro
09.19.2009, 07:45 AM
that's what a flip flop switch does ^^ ;)
so it'd be set to fail in an open position
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.19.2009, 04:58 PM
In my experience, having no on/off switch works great. You shouldn't have your battery plugged in when your car is not running anyway.
Area 52 Ranch Raceway
T.R.C.R.
shaunjohnson
i pwn nitro
09.19.2009, 05:02 PM
i just dont like the massive ark you get from the caps charging when you first plug in the ESC.
and you cant beat plugging in your batts in prep for a race, walk to the track, hit the button (i have mine so it is accessible from outside the body) and walking away from the car as it twidles it's little diagnostics tune
after the race you just come back and rather than taking off the body just hit the switch then go marshaling (our club policy) then come back later and un-plug.
shaun
Unsullied_Spy
Unsullied_Spy's Avatar
09.19.2009, 07:22 PM
What's interesting is that MMM, with the switch still attached, sparks every time I plug it in regardless of the position of the switch. The switch works just fine and there's nothing wrong with my MMM...
brushlessboy16
09.19.2009, 09:19 PM
the sparks are from charging the capacitors on the Monster. it will happen regardless.
Unsullied_Spy
09.20.2009, 06:13 AM
I know. There are people saying that it doesn't spark without the switch and that running without the switch makes it spark and causes issues but it does it either way.
shaunjohnson
i pwn nitro
09.20.2009, 05:12 PM
i thnik you got me on that one unsullied
if switch is on, caps still get charged, if switch is off, main board gets it's caps charged while brain board dosent get power.
ok so most people here gave up on the switch, but is that because you didn't like the reliability?
i just figured that leaving the main board powered for a little while whilst you go marshal a 10 min heat wouldent be so bad.
fets are pretty safe without a signal!
Metallover
RC-Monster Spudgunner
Metallover's Avatar
09.19.2009, 09:23 PM
I think the switch should be connected with a connector. Something like a jst plug or the connector on the blade mcx battery. Include a cover for the connector or a blank connector so dirt doesn't get in it if the esc is ran without the switch. Make it so when the switch is unplugged the esc is on. That is the best solution IMO.
FG101C
09.20.2009, 02:07 AM
Clip, solder, heatshrink.
big greg
09.20.2009, 02:22 AM
no switches!!!!!!!!!
Unsullied_Spy
09.20.2009, 06:18 PM
Switches are, IMO, best for programming and getting the ESC calibrated to your radio. I have a few ESCs without switches and I don't know how I'd be able to plug in the Deans and work the transmitter if I weren't ambidextrous. I do think that they should go with the open circuit switch though, my MGM is that way and since the switch broke off it has still worked just fine. My problem with having a switch is it's inevitably going to get dirty and messed up, so it would have to be a well-protected switch (rubber boot over the opening in the case would suffice).
bcltoys
09.20.2009, 08:04 PM
So whats the word switch good and needed or does not matter or use it till it fails then get rid of it.
brushlessboy16
09.20.2009, 08:29 PM
unless you really need it or have some meansof protecting it from dirt- trash it.
In my 8ight I run a Jst extension under the battery tray to my radio box, with a switch in the standard position (as nitro) wired up to my esc's.
Has one of those silicone rubber boots and works great.
