brushlessboy16
brushlessboy16's Avatar
09.19.2009, 09:19 PM
Originally Posted by Unsullied_Spy View Post
What's interesting is that MMM, with the switch still attached, sparks every time I plug it in regardless of the position of the switch. The switch works just fine and there's nothing wrong with my MMM...
the sparks are from charging the capacitors on the Monster. it will happen regardless.
Unsullied_Spy
Unsullied_Spy's Avatar
09.20.2009, 06:13 AM
I know. There are people saying that it doesn't spark without the switch and that running without the switch makes it spark and causes issues but it does it either way.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
09.20.2009, 05:12 PM
i thnik you got me on that one unsullied
if switch is on, caps still get charged, if switch is off, main board gets it's caps charged while brain board dosent get power.
ok so most people here gave up on the switch, but is that because you didn't like the reliability?
i just figured that leaving the main board powered for a little while whilst you go marshal a 10 min heat wouldent be so bad.
fets are pretty safe without a signal!
  Send a message via MSN to shaunjohnson
