mbx5t conversion questions
kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
mbx5t conversion questions - 10.02.2009, 09:40 PM
hey there guys
i have just taken delivery a mbx5t chassis that i am starting a brushless conversion with.i plan to use a mmm v3 2200kv motor esc combo on 4s 5000mnh lipos with rcmonster mounts. what size/type of pinions should i use.i dont want super huge speeds,more looking for decent run times.
10.02.2009, 09:44 PM
First, welcome to RCM! On my mbx-5T I run a 15 pinion w/the same motor esc combo you have and so far so good as far as temps go. I am running my set up on 5s though....I will post a pic in a few mins...
kneedeeppow
10.02.2009, 09:53 PM
wow,that was fast i have been looking thru the forums on here while i waited for my membershipto be activated.there is alot of directly relevant info on here which has been really helpful.from what i read the mmm system sounds pretty good.i am sure the tekin etc systems are good to. i come from a touring car(1/10) back ground but go sick of the rulebook stiffies ruining the fun so have decided to go 1/8th offroad for a some fun.does the rcmonster mounts bolt straight in or is there some drilling involved? can i re-use the reciever box i just pulled out of my chassis? it looks like it would keep the reciver etc dry and dustfree.
10.02.2009, 09:55 PM
here are a couple of pics. of my conversion. Yes, the RCM mount bolts right on...no mods. Many of use put our rx in balloons as I did...simple, yet effective. What I did was use a piece of the stock carbon fiber mount...cut it and put spacers under it to allow clearance on top of the new servo mount for my cable ties
kneedeeppow
10.02.2009, 10:01 PM
that looks nice and tidy. i was wondering where to place the esc. have seen some pictires of esc on top of the center diff which i thought might be a bit top heavy. your placement makes it look clean. are deans plugs ok for 4s 5000s? the batterys i am looking at (http://www.hobbycity.com/hobbycity/s...idProduct=9179) have plugs i have never seen before so was planning on swapping them for deans
riverat1540
riverat1540's Avatar
10.02.2009, 10:05 PM
if u get a 5s pack and gear down u would have a cooler running system, more on demand torque and extended run times, u will have a bit more weight but make up for it in power, alot of people here are running 5s in their truggys with good results
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
kneedeeppow
10.02.2009, 10:13 PM
to gear it down do i change pinion and spur or just one of them?
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
10.02.2009, 10:18 PM
pinion is all you need to change. Run it with say a 15 t to start and constantly check temps...and then adjust gearing accordingly...in case you haven't see this...this is a great guide
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
Warm motor, warm controller, warm batteries = happy components
Hot, warm, and cool vary as well, so here's another general rule:
Hot for a motor = generally over 160F (71C)
Hot for a controller = generally over 150F (66C)(or "thermal" range for the controller)
Hot for batteries = generally over 150F (66C) for nimh, 130F (54C) for lipo
Warm for a motor = generally 100F (38C) through 150F (66C)
Warm for a controller = generally 100F (38C) through 130F (54C)
Warm for batteries = generally 100F (38C) through 130F (54C) for nimh, ambient temp through 120F (49C) for lipo
Cool for all components = generally ambient temp and up to 10 degrees F (5.6C) more
kneedeeppow
10.02.2009, 10:20 PM
are you running a 15t on the factory spur gear that runs in a nitro mbx5t?
nuova faor sf501
10.02.2009, 10:06 PM
As far as batts. go I would go for the 30c version of the ones you were looking at...I am running the 5s 30c version and love them and you can't beat the price. The mount I used is this one..http://www3.towerhobbies.com/cgi-bin...?&I=LXVEC2&P=7. I actually bought the mount for another project, but never used it and remembered I had it and it worked great for this truggy. just need to drill 3 holes and you are done.
Deans are widely used and work great.
10.02.2009, 10:10 PM
Here is a pic. of the esc mount...not the best pic..but it does allow air flow below the esc. You can see the 3 screws you would need to drill
kneedeeppow
10.02.2009, 10:15 PM
what is 'normal' operating temperature range for mmm? i should definatly look into a temp gun as well aye
nuova faor sf501
10.02.2009, 10:27 PM
Yes I am...I haven't been able to test a full batt. though...only 10-12 mins on 3 different occasions, but, the temps were v/good after 12 mins. Of course, I am only using 80% of my throttle...any more and it is just stupid fast
kneedeeppow
10.02.2009, 10:31 PM
i read people mention the metal pinions/spurs are very noisey? do you find this to be the case. i would imagine these things would chew thru plastic spurs pretty fast.
nuova faor sf501
10.02.2009, 10:40 PM
It is a little noisy, but, the way I look at it is I don't have change spur gears! I have never chewed up a stock 1/8 spur gear yet....so I am sticking w/what works.
