which battery would you go for---hobbycity
t-maxxracer32
t-maxxracer32's Avatar
which battery would you go for---hobbycity - 11.17.2009, 04:23 AM
looking at 3 possiblities for my 2s pede setup
http://hobbycity.com/hobbycity/store...dProduct=9748#
http://hobbycity.com/hobbycity/store...idProduct=8973
http://hobbycity.com/hobbycity/store...dProduct=10083
im not set on these 3 so if you know of something better then let me know would like it to be able to ship from a us warehouse but this is not a must..
but keep in mind it has to be able to fit into the stock pede chassis...
thanks
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.17.2009, 04:54 AM
I would go for the 4000mah one.
I have no idea what fits or not though (sorry).
But from a quick glance, here is what I saw.
The 4000mah is rated 25C (so that's 100amps) while the other two are 30C.
The 3300 30C means 99amps, which is more or less the same, but you are paying more for less capacity - I see no point, so that one is out.
The 5000mah one costs more than double than that of the 4000mah one, though, of course, it provides much more current (5000mah at 30C is 150amps). However, I don't think it'll make much of a difference unless your pede is 10lbs and geared to 80mph.
So, based on that, I would recommend the 4000mah one. It is the cheapest and provides plenty of juice (assuming the C ratings and what not are accurate).
phildogg
phildogg's Avatar
11.17.2009, 08:13 AM
the batts are not in the US they are in germany warehouse.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
11.17.2009, 11:10 AM
Buy the best battery you can afford... So I would go with the 2s 5k pack. And those you linked to are only available to ship to Germany and France.
This is the pack I would buy, 40c and cheap! :
http://hobbycity.com/hobbycity/store...00mAh_2S1P_40C
phildogg
phildogg's Avatar
11.17.2009, 11:26 AM
will he not need to sand away alittle of the sides to get that battery to fit? I had a 3s 5k before and they are alittle too wide at 50mm.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
t-maxxracer32
11.17.2009, 03:16 PM
oh and ya this battery is a little long..
11.17.2009, 03:22 PM
Yep, forgot about the specs. I run a flm chassis in my pede, so dimension is not that big of a deal for me!
blueb8llz
11.17.2009, 06:02 PM
dude, thats a frickin deal!! i wonder why those packs are so cheap, im thinking of picking a pair of those for my emaxx. im not even looking for new packs, but those really caught my eye.
can anyone verify if those will fit into a 3905 emaxx?
11.17.2009, 06:27 PM
too wide for an emaxx tray. Not much use unless you plan to make your own tray (as i will for the 6s I just bought for the lst) or have a flat chassis (like the flm pede chassis).
HC also have a killer deal on the 4500 2s2p flat LiFe packs, 25 bucks or something like that. I bought one just to try out. Maybe in a brushed truck so I do not have to use a esc with a lvc.
junkman
11.17.2009, 12:07 PM
I have several of the 4k 25c hard cases. They fit perfect in a stock pede. I am afraid any of the 5000's are going to need some serious dremeling. I'd pick them up, they will fit in the majority of vehicles without modding, work great, and cheap. I havn't tried any of the 5k hard case, but they look squared off, might still be fine in the pede, but I don't kow about other stock type cars.
t-maxxracer32
11.17.2009, 03:15 PM
oh shoot i figured DE warehouse meant deleware haha
no wonder some said US warehouse...
thanks for the help i think ima try and find a US warehouse battery if possible..
t-maxxracer32
11.17.2009, 04:17 PM
i was thinking about trying to pick one up for cheap just so my options would not be limited but ima hold off on it for a bit
t-maxxracer32
11.17.2009, 06:34 PM
ordered 3 diff packs...
http://www.hobbycity.com/hobbycity/s...dProduct=10309
http://www.hobbycity.com/hobbycity/s...idProduct=9435
http://www.hobbycity.com/hobbycity/s...idProduct=8357
ill let you know how they do!
t-maxxracer32
11.17.2009, 06:35 PM
james i see your post about the life packs
what are the hype about them? or whats different about them that makem special?
id like to know how to care for them before i gettem in
thanks
