powerdome charging
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
powerdome charging - 12.28.2009, 06:09 PM
well my parents got me one of these for christmas as a powersupply at my local track... i love it but im worried about charging it.
its a lead acid battery and its supposed to take 36 hours to charge.. im just worried as i wanna always have it topped off so i dont know how long to leave it charging...
it has a voltmeter built in which will tell me the voltage but when should i stop it? it goes all the way up to 15v even tho the battery is a 12v?
i just dont want to damage the battery by charging it to long
http://www.autobarn.net/wag2254.html
12.28.2009, 07:11 PM
For longevity you have the right idea, always keep it topped off. I would imagine fully charged you could see 13.8v or more, once you have it fully charged take note of the voltage and that will be your goal. At the end of the charge it should feel luke warm, if it starts to get hot you are overcharging it.
A small "smart" trickle charger would be ideal for keeping this going for you, as they shut off when charged and turn on when the voltage sags.
jokerjustin
12.28.2009, 07:25 PM
i cant really feel the actual battery as it is enclosed.. it came with a wallwart charger... is there a way to check if it is a "smart" charger?
12.28.2009, 07:32 PM
You'll feel heat through the case if it's getting hot.
You'll have to check the instructions on the charger. Does it say to unplug it after the 36 hours? Then it's not. If you can keep it plugged in it is.
Does your r/c charger have an sla option?
J57ltr
12.28.2009, 08:46 PM
I haven't seen a booster box yet that has any sort of smart charging. Most just have a walwart that is rated for about 12-14V and usually an amp or less and you just charge them by time. Even a 12V walwart will eventualy get to about 13.5V when the load drops enough. You could use the charger it came with to charge it then switch to one of these
http://www.harborfreight.com/cpi/cta...emnumber=42292
to keep it at a full charge.
Jeff
redshift
RC-Monster Square Tube
redshift's Avatar
12.28.2009, 08:41 PM
Battery Tender Jr. be the thang...
http://www.amazon.com/gp/product/B00...3YZ7P330TFRH48
redshift
redshift's Avatar
12.28.2009, 08:49 PM
Or that^ lol.
J57ltr
12.28.2009, 09:43 PM
Actually the one you posted would do both so I think it would be a better bet.
Jeff
