antennas on spektrum rx
antennas on spektrum rx - 01.02.2010, 01:32 PM
Just took the plunge into 2.4 and was wondering if you guys extended the antennas a little on the rx to mount into a tube or just let them as is
bruce750i
bruce750i's Avatar
01.02.2010, 01:37 PM
Special type wire, don't even look at it.
Jabe
01.02.2010, 01:44 PM
No need to extend, leave as it is.
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
01.02.2010, 01:57 PM
so where do u guys put the wire? does it need to be placed in a special way?
01.02.2010, 02:08 PM
Ok I will leave it as is...
skellyo
skellyo's Avatar
01.02.2010, 02:59 PM
Coil it up with a small diameter tool like a screwdriver and just leave it as a little pigtail under the body. It's short enough that if you give it a good tight coil, it'll stay put without issue.
01.02.2010, 03:14 PM
You need the wire to stick up at least 1 inch for optimum performance. I usually use a radio box or a mount that also has a antenna tube holder, then just cut a short piece of antenna tube to hold the wire. I leave it under the body, so it stays safe if I flip over.
01.02.2010, 03:25 PM
Upon further inspection, it looks like I have just enough wire to use a sm. mount and sm. amount of tube where the mount is now
brushlessboy16
brushlessboy16's Avatar
01.02.2010, 03:20 PM
I keep all mine inside the radio boxes- no problems thus far
01.02.2010, 03:22 PM
I don't have a radio box...my rx are in balloons on top of steering servo..hence my concern of the wires moving and getting caught around servo horn
