How to make my buggy faster?
superek4
superek4's Avatar
How to make my buggy faster? - 01.14.2010, 09:28 AM
My jammin x2 only accept max 16 size pinion with 46 slip diff. I m using 1512/2.5d neu. Batt is 4s 5000 zippy@30c.
My EPA is 150% punch at 50%. I tried 70% it's hard to drive. I was thinking the only way is to change higher kv motor.
Anything else I can do wo spending?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
bdebde
That's All Folks!
bdebde's Avatar
01.14.2010, 10:52 AM
More voltage! Why 16 max pinion?
superek4
superek4's Avatar
01.14.2010, 12:40 PM
Jammin conversion can only accept up to 16 pinion, I tried 17 the meshing was too tight.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
01.14.2010, 11:09 AM
The 1512/2.5d could use an extra cell if you want to go faster. It being around 2000kv, 5s would make it go faster without gearing up too high.
01.14.2010, 11:23 AM
Yeah, 5s sounds like the way to go, depending on the esc of course...
superek4
superek4's Avatar
01.14.2010, 12:38 PM
5s 5000 for a buggy is too heavy.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
superek4
superek4's Avatar
01.14.2010, 12:45 PM
I try not To spend too much, I hv a CRT on 6s 5000 n I was planning to buy 6s 3000. If I will buy 5s lipo I will be spending too much.
I m trying to swap my rcm x1 CRT motor mount to my jammin x2 n my x2 jammin motor mount to my truggy. The rcm motor mount can accommodate larger pinions.
Problem is the buggy mount is too short for a 50slip diff. So I need spacers to the mount.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
brushlessboy16
brushlessboy16's Avatar
01.14.2010, 01:00 PM
the higher the voltage, the less miliamp you need for the same runtime if you are using4s 5000mah, you can probably use 5s 4000mah. about the same weight
01.14.2010, 01:29 PM
Unfortunately, the only options you have to make it faster are:
- New motor with a higher kv. A CC/Neu 2650 motor runs great on 4s and the higher kv means you don't have to gear as tall and are within your gearing limits of the motor mount.
- Gear higher. I assume your gearing limitations are with the slot length on the motor mount. You might be able to modify the motor mount to lengthen the adjustment slots. A dremel with a carbide cutting bit is probably the best bet here. But, be careful about gearing up too high. 46/16 is already pretty tall. If you gear too high, you will be stressing the ESC as it tries to get an adequate back-EMF signal at low speeds. I personally wouldn't go much higher, if any, that what you are currently geared at.
- Go with higher voltage. 5s would be the best bet. If you are concerned about cost, Turnigy packs might be an option.
No matter what, it is going to cost more if you want more speed. You'll just have to decide which is the cheapest route to take.
jhautz
jhautz's Avatar
01.14.2010, 07:52 PM
or BIGGER TIRES! Try mounting some Savage XL tires on it. It'l go faster....
to make it...
or break it...
Silent...But Deadly
01.14.2010, 10:47 PM
True, I forgot to mention that. But just remember that going with larger tires is like gearing up and the same caution about gearing too high applies.
bdebde
That's All Folks!
bdebde's Avatar
01.14.2010, 04:14 PM
Smaller spur gear fit?
riverat1540
riverat1540's Avatar
01.14.2010, 06:00 PM
i would say the x1 crt mount would be good as its made for the that huge 62t pinion
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
superek4
superek4's Avatar
01.14.2010, 06:08 PM
Problem also the batt tray can only fit 140mm length. So most turnigy packs or 40c pack can't fit. I am trying 17 teeth n see how's the temp. Smaller spur? I think rcm slip smallest is 46
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
George16
Supermaxx
George16's Avatar
01.14.2010, 11:14 PM
Get rid of the 45/10 diff gears you have and change it to the regular Ofna 43/13 diff gears. I'm currently converting an X2 and that's the first thing I did since I have a bunch of 43/13 diff gears.
46/16 is not tall on an X2 due to the lower diff gears of 45/10. I don't know why Ofna went with this gearing but it sucks when you do a conversion.
I'm using a spur pinion combo of 48/15 on my son's X1 which uses the 43/13 diff gears.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
