No Pistons
Inferno GT2 Battery Tray -
02.04.2010, 06:42 PM
Has anyone bought and installed this tray?
I would love to see a picture of it before I buy one.
Thank you in advance.
04.02.2010, 10:39 AM
Same here.
Site Owner
pictures -
04.03.2010, 12:04 AM
Ask and you shall receive. The tray is built on the same concept as the MBX6 and 808 trays in that is is a direct bolt on and is designed to allow wire routing under it, as well as ESC mounting in the rear. The pictures show the whole car converted with all RC-monster parts - 2 speed adapter and gears, double servo plate, battery tray and kyosho motor mount. :)
04.06.2010, 08:16 AM
Mike, what specifically is the setup (motor, gears, lipo, etc..) ?
Site Owner
04.06.2010, 09:15 PM
The car has the Castle MMM 2200Kv combo with the 2 speed adapter and 17/23 gears using a 4s Lipo(4200mah 35c Hyperion G3) and Ofna foam tires.
04.07.2010, 04:49 AM
Motor and esc run cold ?
The shift point to second speed must to be changed ?
Thanks
Site Owner
04.07.2010, 09:39 AM
Heat is not an issue with this setup - the shift point usually requires tuning based on the track/bash spot. The ST-RR brakes work better than the stock setup, too(a worth-while change for real stopping power).
04.07.2010, 10:40 AM
Ok Mike, I asked about shift point because my fear is that the motor torque can destroy transmission.
What do you think?
Site Owner
04.07.2010, 10:54 AM
Yes - the 2nd gear can be destroyed rather easily, actually. The original Gt tranny works better, as there is only 3 tooth difference between 1st and second(doesn't hit as hard). I set the shift point fairly low(shifts early) to minimize the damage. :)
04.07.2010, 12:32 PM
ok, then what better 2 speed setup do you recommend for my Inferno GT1 to minimize the damage ?
Site Owner
04.07.2010, 07:19 PM
The GT1 tranny works better than the GT2 tranny.
04.08.2010, 05:49 AM
Ok Mike, I hold the original GT1 tranny.
But, what pinions to buy for to have high speed and low heat ?
Site Owner
04.08.2010, 01:13 PM
17/20 would be a good place to start. :)
04.09.2010, 06:29 AM
Even with the GT1 tranny is recommended to set the shift point fairly low ?
18/21 how do you think?
Thanks for your kindness
06.08.2010, 01:57 AM
I see that 51.5mm x 169 is the size you list for the gt2 tray but is that the overall size or is that how big of a battery can fit in the tray? If that's the overall size can you custom make a try to hold a battery as big as 160mm x 48mm and still have an integrated esc shelf?
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
