on the Sr3300T spektrum rx...a question
on the Sr3300T spektrum rx...a question - 02.06.2010, 10:47 PM
I am already using the 3 channels...last one is for an external bec...so this leaves me short on the fan plug for my mm. Can I power the fan on top of the mm through any other slot on the rx?
Or am I SOL. Too much of a chicken to find out..would rather ask than ruin a $ 100- rx
02.06.2010, 11:13 PM
NO!!! The sensor ports are 3.3v IIRC use a Y splitter - the traxxas ones are cheap
02.06.2010, 11:15 PM
I read that Chris after posting. So I can split the AX ch which has the bec in it or should I do another ch.
This is why I double check first!
02.06.2010, 11:14 PM
Yup I was right....
From the manual
Power the receiver through any port that is not
a 3.3V Telemetry port. The amber LED will flash
continuously, indicating the receiver is in bind mode.
WARNING: Do not power the SR3300T
through the LAP, TEMP, or RPM Port the
receiver will be damaged
So it goes I wouldn't draw power either and you'd only get 3.3v
02.06.2010, 11:16 PM
Doesn't really matter - The + and - on all the other channels are linked...
02.06.2010, 11:24 PM
Figured as much...thanks again
