hb pro diff?
stampy
stampy's Avatar
hb pro diff? - 03.27.2006, 07:33 PM
what comes with the hb pro diff if i get it from mike for $65? just wondering if it comes with any thing else cause towerhobbies as it for like $42. im a poor arse and need to save as much as i can on this truck of mine.
squeeforever
squeeforever's Avatar
03.27.2006, 07:37 PM
the ones from mike have the bearins, pinion gear, and shim i think. the ones from tower are just the diff, no pinion gear or anything.
stampy
stampy's Avatar
03.27.2006, 07:55 PM
cool tnx squee. ill have to order up a pair from mike when i get around to doing my diffs
coolhandcountry
coolhandcountry's Avatar
03.28.2006, 07:40 AM
The pro diff has a lower gearing than the other hb diff. It is 4.3 ratio verse 3.31.
Peace!
Country
Help support the
Rc-Monster
Buy here
stampy
stampy's Avatar
03.28.2006, 05:39 PM
i was typing that ratio in to the speed calc thing on the net and found something weird dont know if my be i made a mistake but with stock emaxx diffs emaxx trans in second and a 51tooth 16tooth spur an pinion with 1950 8 i came up with a rpm of 36274 and a top speed of 41 with a 5.5" tire with .5" of ballooning. but when i plugged in the 4.3 ratio hb diff i would need 24 tooth pinion to get the same top end. well theres 2 problems i see with that big of a pinion. 1 thats a lot of rotating mass for a motor to have to spin up and 2 mike doesnt even have a 24 tooth the biggest on there is 20 so how would you go about fixing this prob? obw i could be using the speed calc thing wrong to so im a little :025: just got up :027:
Serum
Serum's Avatar
03.28.2006, 04:41 PM
The pro uses hardened gears inside the diff.
I don't think you get the shimms. just the diff, with bearings mounted and two bearings and the pinion gear.
coolhandcountry
03.28.2006, 06:21 PM
You are right to assume the pinion would need to be a 24 toother with the 4.3 diffs. The hb also makes the 3.31 diffs which would take abouta 18 or 19 to make it out right.
Peace!
Country
Help support the
Rc-Monster
Buy here
stampy
stampy's Avatar
03.29.2006, 05:33 PM
do they make the 3.31 ratio hardened as well? and can mike get um?
boss 302
03.29.2006, 05:55 PM
mike has the 3.31 ones in the store and they too are hardened http://www.rc-monster.com/proddetail...GY_DIFF&cat=47
maxxdude1234
maxxdude1234's Avatar
03.30.2006, 08:23 AM
One question. Are both the PRO and ordinary radial cut? Thanks.
Serum
Serum's Avatar
03.30.2006, 08:47 AM
Helical
maxxdude1234
03.30.2006, 08:52 AM
Originally Posted by Serum
Helical
:005: same difference, cheers Serum.
Darren
03.30.2006, 10:27 AM
Will these fit straight into the E-Maxx? I keep shredding stock diffs on my HV E-Maxx :019: :031: .
Serum
Serum's Avatar
03.30.2006, 10:38 AM
No, they need a 1/8th FLM bulkless to use.
You can get aluminum cups for your hvmaxx with M3 screws. Since it's a rather weak setup, you won't be needing the 1/8th
You might as well consider getting the new differential cases from the T-maxx 3.3 it uses 4 instead of 2 screws. (traxxas 4980X)
Darren
03.30.2006, 04:45 PM
I seen the ones with the 3MM screws, the stock screws in the nova diff cups we had went walkies! Will def. look into it.
Thanks
