Feigao 6L help
JUS4SHO
Feigao 6L help - 07.14.2010, 03:49 PM
i just aquired a Feigao 6L motor for my slash 4x4 , with a vxl-3s and i have a few newbie questions
1) what gearing should i use? can i run 15/50 safely (i plan on using a doule integy fan on the motor)
2) this should be faster than the stock motor?
3) the wire colour code does not match than of the vxl-3s how do i wire it up
thanks in advance for all the assistance
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.15.2010, 06:33 AM
1) it should be fine on 2S...watch the temps on 3S though
2) definately....much faster. it will also have more torque.
3) the middle wires are always the same. the 2 outer wires can be changed to reverse the rotation.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
JUS4SHO
07.15.2010, 09:36 AM
thanks very much for the help buddy
07.19.2010, 11:45 PM
i would avoid running 3s. As a rule I never run feigaos past 35,000 rpm
DwightSchrute
07.20.2010, 08:15 AM
the velineon motor is a feigao and traxxas runs it on 3S at almost 45,000rpms.
I run mine in my 8ight buggy on 3S all day long with no issues. those motors can take alot of abuse imo.
07.20.2010, 10:19 AM
3500x11.1= 38,850. Not 45,000. And even then, velineons fail all the time on 3s.
The 6l is 4000kv. I would not run it on 3s. Feigaos don't like going above 35,000rpm.
DwightSchrute
07.20.2010, 11:26 AM
Harold....
when do you run your velineon on 11.1V?
a charged lipo is 4.21V per cell....
so 12.6 x 3500= 44,100
i've had velineons for years, and never burned a single one on 3S. Granted, the 6L is a 4,000kv motor. it would run right at the 50K mark, but i've done that too with no issues.
as long as you check temps often, i don't see any issues. they're strong motors.
07.20.2010, 12:00 PM
Harold....
Dwight.....
I don't run velineons.
a discharged lipo is 3.0v per cell
so 9x3500= 31,500
I've had feigaos for years before they were rebadged as velineons,and burned several on different voltages.
as long as you check temps VERY often, i don't see any issues. they're weak problematic cheap inefficient motors.
It's neato that you're liking them. They are crap.
