SERVO Help - Custom Build
kladal
SERVO Help - Custom Build - 07.26.2010, 10:01 PM
Hello,
I have a custom build that will only barely resemble the truck you see in the pictures below by the time it's complete.
Here are the specs:
-Motor = 2217 2y 640kv CC/Neu
-ESC = Megapower 120A
-Battery = 10s (two 5s)
-BEC = Castle Creations BEC Pro at stock 5.5V
-Tires = IMEX Swamp Kong 8.5"
-Weight = estimated 22-24 pounds
I will be installing TWO steering servos for four wheel steering. I've been advised that I need a high-torque servo.
1. Any recommendations on how much torque I should have? (Thus far I've been considering the Futaba BLS352 OR SAVOX SC-1256TG).
2. Which between these two uses less power?
3. Does anyone recommend any other servo?
4. I've been told two servos be linked via a y-hardness. How will they each attain sufficient power??
5. How do I connect these so they each do the opposite?
6. Does anyone see any problems with this steering system?
Thank you for your input!
(When I asked a servo question in my other thread, no one responded).
reno911
Smelly Nitro meet your maker!
reno911's Avatar
07.26.2010, 10:03 PM
Hitec 1/5th scale may be up your alley. Unless you run a higher bec voltage.
07.26.2010, 10:07 PM
Just install one front and rear 7980 on 7.4v - 600 oz will be enough
Reality is a 7950 at 480 oz would be OK to...
07.26.2010, 10:09 PM
That futaba is pretty weak only 250 oz
whitrzac
Can't catch this...
whitrzac's Avatar
07.26.2010, 10:38 PM
http://hobbycity.com/hobbyking/store..._.118sec_/_78g
kladal
07.26.2010, 10:42 PM
Why does this vehicle require that much torque??? Tires+weight??
Can someone tell me OR post a pic as to how I should hook up the extra LiPo battery?
Thank you.
reno911
reno911's Avatar
07.27.2010, 12:02 AM
Why an extra lipo? Can't you set the voltage on the Castle BEC?
kladal
07.27.2010, 12:05 AM
Reno911 - since I'm using two servos, what should I set the voltage to if each receives 6V? Is it a simply 6+6 = 12V? Please keep in mind I'll be connecting the two via a y-harness.
Thanks.
reno911
reno911's Avatar
07.27.2010, 12:08 AM
Thanks.
You don't need to supply twice the voltage, but it will pull more amperage. Which the BEC should be capable of.
reno911
reno911's Avatar
Then set your voltage to 7.4 or higher if needed.
reno911
reno911's Avatar
07.27.2010, 12:06 AM
What receiver will you be using?
kladal
Receiver: Airtronics MX-3 Sport 2.4GHz FHSS-2
crazyjr
crazyjr's Avatar
07.29.2010, 12:02 AM
https://www.airtronics.net/index.php...aitfile_id/56/
One problem, in the specs on the first page, max voltage is 6 volts(5 cell NIMH). I know most NIMH are higher first off the charger, not sure how much or if the reciever is really designed for higher volts
