kladal
07.27.2010, 12:05 AM
Originally Posted by reno911 View Post
Why an extra lipo? Can't you set the voltage on the Castle BEC?
Reno911 - since I'm using two servos, what should I set the voltage to if each receives 6V? Is it a simply 6+6 = 12V? Please keep in mind I'll be connecting the two via a y-harness.
Thanks.
reno911
Smelly Nitro meet your maker!
reno911's Avatar
07.27.2010, 12:08 AM
Thanks.
You don't need to supply twice the voltage, but it will pull more amperage. Which the BEC should be capable of.
